Dana 44 outer wheel bearing
#825959
07/19/07 02:03 PM
Hey everybody, Are you guys and gals getting these pressed on using an actual press or is the shade tree mechanic method of pounding it on using the carcass of the old bearing and a hammer sufficient?
My e-brake locked up in the driver side rear wheel and the heat smoked the seal and bearing. Literally smoked. Thanks, --jeremy <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Dana 44 outer wheel bearing
[Re: HCMP]
#825960
07/20/07 03:06 AM
i gather you're talking about the wheel bearing on a rear D44. .. I use a long pipe sleeving the axle shaft and a BFH to drive it home... it can be done without a press.
-Rob
[Re: HCMP]
#825961
07/20/07 05:14 AM
Geez, glad that didnt happen to mine. My drivers side e-brake cable went bad and kept sticking on. It would eventually pop loose but I know that brake go pretty warm. Jerry hooked me up with another cable off an '01 rodeo and it got it changed out last week. Pain to do on 2nd gen rodeos, have to drop the tank to get to one of the brackets.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO on US Wheel 94 series 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
[Re: HCMP]
#825962
07/20/07 12:08 PM
[Re: HCMP]
#825963
07/21/07 09:14 PM
I too use the long pipe sleeve and it works just fine.
94 Rodeo sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url] http://community.webshots.com/user/94rodeo[/url]
