Re: Is it time for a new radiator? [Re: Crallsjeep] #826118 07/25/07 11:55 PM
BigJim Offline
The fuelies I am aware of all have TWO senders in the coolant jacket. ONE of them sends the propper temp to the gauge.
The OTHER one is a switch and sends only sends a go-nogo to the computer to tell the computer the operating temperature has been reached so the computer can change the timing and mixture from start to run... BOTH will screw into the same holes! However the ones I have seen have different lectric plugs on them to caution against mistakes in which is used.
I have seen guys making the wrong one plug into the system by FORCING the wrong plug! Needless to say the wrong sender will NOT work.
Re: Is it time for a new radiator? [Re: BigJim] #826119 07/27/07 03:16 PM
Crallsjeep Offline OP
Well against popular opinion, I changed my radiator, with the AC on, in traffic, on a hot day (90+) I haven't overheated, not saying it wont today on the way home but for the past several it's been running normal
Re: Is it time for a new radiator? [Re: Crallsjeep] #826120 07/30/07 06:07 PM
DBL_DTY97TJ Offline
If that was the original rad. I completely agree it was time for a change....I can't recall having one last more than 7 years or so.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Is it time for a new radiator? [Re: DBL_DTY97TJ] #826121 07/30/07 06:39 PM
I have owned the Jeep for 4 of thse years, I just have a problem throwing out a radiator, that is perfect on the outside
Re: Is it time for a new radiator? [Re: Crallsjeep] #826122 07/30/07 10:57 PM
DBL_DTY97TJ Offline
They all look good on the outside - even when they're filled mostly solid with junk inside....Send it to the recycler... <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.080s Queries: 15 (0.006s) Memory: 0.6100 MB (Peak: 0.6737 MB) Data Comp: Off Server Time: 2026-10-26 11:15:53 UTC
