Clutch master cylinder? Slave cylinder or something else?
#826341
07/22/07 10:44 PM
I replaced my clutch master cylinder yesterday because it was leaking bad. I got everything correctly assembled and bled the system with a one man bleeder. I am pretty certain that I cycled new fluid through the entire system. So here the problem, When the vehicle is started I cannot get it to go in to any gear at all. I have tried to bleed it repeatedly. There is a good range of movement down at the slave cylinder as well. Any ideas?
Re: Clutch master cylinder? Slave cylinder or something else?
[Re: Scotty_Gotti]
#826342
07/23/07 05:21 AM
Did you actually check the pedal play/adjustment? LINKY
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5870 MB (Peak: 0.6350 MB) Data Comp: Off Server Time: 2026-06-18 12:24:05 UTCValid HTML 5 and Valid CSS
