can the freeze plugs on a 92 yj 4.0 bereplaced with out removing manifolds
#826614
07/24/07 04:27 AM
can the freeze plugs on a 92 yj 4.0 bereplaced with out removing the manifolds
92 jeep yj re 4 inch lift revolver shackels front and rear 36 inch shocks in front 27 inch in rear 34 swampers ltb 2inch wheel spacers
Re: can the freeze plugs on a 92 yj 4.0 bereplaced with out removing manifolds
[Re: cbrazor]
#826615
07/24/07 04:29 AM
yes. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#826616
07/24/07 04:32 AM
ok how <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: cbrazor]
#826617
07/24/07 05:32 AM
Find a way to punch the existing one into the block, it will not hurt anything in there. The put one of the expandable ones in place and tighten the bolt. Ive never done one on that engine but have on many others. It is usually tight to get to but it should be doable. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#826618
07/25/07 01:26 AM
Find a way to punch the existing one into the block, it will not hurt anything in there. The put one of the expandable ones in place and tighten the bolt. Ive never done one on that engine but have on many others. It is usually tight to get to but it should be doable. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" /> so by leaving the plug in the block it won't cause a restriction in flow???? I usually take a self tapping screw and put it through the plug and then pull the plug out with a piece of mechanics wire wrapped and tied around the ST screw
always working
[Re: Macka]
#826619
07/25/07 01:45 AM
If they are all rusted and thinned out the screw will not work. Punching it into the coolant jacket has been done by just about everyone for many years. I've never heard of any ill effects. When punching on one side or the other many times the thing will turn sideways in the hole and that enables pulling out with pliers. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#826620
07/25/07 02:07 AM
If they are all rusted and thinned out the screw will not work. Punching it into the coolant jacket has been done by just about everyone for many years. I've never heard of any ill effects. When punching on one side or the other many times the thing will turn sideways in the hole and that enables pulling out with pliers. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" /> X2
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
[Re: BigJim]
#826621
07/25/07 03:39 AM
thanks big jim <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6182 MB (Peak: 0.7126 MB) Data Comp: Off Server Time: 2026-10-24 09:51:49 UTCValid HTML 5 and Valid CSS
