Page 2 of 5 1 2 3 4 5
Re: is it time to replace lower plenum??? [Re: 87Montero] #826766 07/26/07 09:54 PM
87Montero Offline
I found a picture I took comparing a 3000GT intake to an SR lower plenium and marked it up for you carlos:
I can't tell you if ALL those holes need tig welded, or if it's just the one on the end after removing the shaft.
Brendan
Re: is it time to replace lower plenum??? [Re: cap510] #826767 07/26/07 09:57 PM
LandRaider Offline
Just to be more specific as far as where I can see/hear the air/vacuum leak coming from, here is a pic:
Also, are you guys saying to remove all 6 butterflies/rod, etc. and tig weld all 6 holes as seen on this picture?
Sorry for the first grade illustration but was the only pic I could find <img src="/forums/images/graemlins/smile.gif" alt="" />
You're not serious are you? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: is it time to replace lower plenum??? [Re: LandRaider] #826768 07/26/07 10:09 PM
lordtrunks Offline
we just took the buttery flys and linkage out and sealed the hole where yours says"air leak coming from here" make sure you get out the bushings too out if they are still there.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: is it time to replace lower plenum??? [Re: 87Montero] #826769 07/26/07 10:43 PM
cap510 Offline OP
WOAH!!
NO, the holes that are to be tig welded are ONLY where the shaft that the butter fly valves are connected to passes through each wall, so the idea is that those holes that you made solid red will be completly open and the holes where the bushings are for the metal rod to pass through the aluminum walls will be closed up, including the front hole, where you have air leaking out of now.
Sorry for the dumb question <img src="/forums/images/graemlins/ignore.gif" alt="" />, I know it's obvious I should not seal those holes but I thought I ask. (hey at least I got your attention) <img src="/forums/images/graemlins/shiner.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" />
Thanks for the inputs guys, I really appreciate all you help! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Do you guys know whether it will make any difference if I seal all the little holes (where the metal rod goes thru) or just the hole where the "air leak" is.
I know for sure I'll be removing all the butterflies and the rod/shaft seen on the pic. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Hopefully after taking care of this the check engine light will go away, I would lthink is cause by the vacuum leak, right?
Re: is it time to replace lower plenum??? [Re: cap510] #826770 07/27/07 01:40 AM
LandRaider Offline
WOAH!!Do you guys know whether it will make any difference if I seal all the little holes (where the metal rod goes thru) or just the hole where the "air leak" is.
I think all you would ABSOLUTLY NEED to do would be to seal the outer ones open to the atmosphere... The ones on the inside could stay open, and prob not hurt anything. You might lose some of the "tuned port" effect since you will esentially be messing with runner length, and tuning. I doubt it will make much difference, and might even help some at lower RPM's.
See how much it would cost to do both, and if it's not much more, seal them all up.
Re: is it time to replace lower plenum??? [Re: LandRaider] #826771 07/27/07 02:12 AM
Ok I'll ask. Why did it have butterflies to begin with?
Re: is it time to replace lower plenum??? [Re: LandRaider] #826772 07/27/07 02:16 AM
Or for a shade tree GOB fix, unhook/plug the vac line, wire the butterflies in the open position shown, and gob on rtv over the leaky end and let it set up before you drive it. Are you SURE it's the butterfly shaft bushing leaking, or is the acutator diaphragm leaking? Piece of vac hose 3' long, one end in your ear, makes a nifty leak finder.
Re: is it time to replace lower plenum??? [Re: fasteddy] #826773 07/27/07 02:24 AM
lordtrunks Offline
one problem eddy those butterflys like to come apart and kill your motor its better just to get them out of there. when we did toastys one had already fell into the motor. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: is it time to replace lower plenum??? [Re: lordtrunks] #826774 07/27/07 03:40 AM
4xmonty Offline
Carlos get a blue tablet for toilets and use that to plug the leaks if its low flow <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Russ <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
Re: is it time to replace lower plenum??? [Re: lordtrunks] #826775 07/27/07 04:33 AM
cap510 Offline OP
I started taking it apart this afternoon and let me tell you it's a pain in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> so many bolts/nuts/hoses/clips/harness/wires, etc, ect <img src="/forums/images/graemlins/scared.gif" alt="" /> that needs to be removed to access the plenum... I am gettin there though! <img src="/forums/images/graemlins/kewl.gif" alt="" />
I hope to have it all apart and have my fabricator come over and tig weld it over the weekend.
I will hate to do this again so hopefully this will solve this butterfly problem and I can move on and forget about it! <img src="/forums/images/graemlins/sleeping.gif" alt="" />
I'll kepp you all posted!
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6487 MB (Peak: 0.7597 MB) Data Comp: Off Server Time: 2026-06-20 15:31:02 UTC
