quick 4 door question.
#827526
07/30/07 01:41 AM
hi, i am asking for my neighbour who just bought a new 4 door wrangler.
i am pretty sure that it is just the runoff from her air conditioning, but want to make sure. it looks like there is a leak from right in front of her transmission drain plug i looked up under neath and there is a spot just above the transmission where there is a clear fluid dripping out at a reasonably fast rate. there is a small uncapped tube there from the body.
I assume this is the drain for the a/c?
let me know if this sounds rite.
thanks.
Re: quick 4 door question.
[Re: DEFBOY35]
#827527
07/30/07 03:27 AM
The only liquid that is clear in a modern vehicle is condensation! Some might come from the tail pipe and what you are looking at is A/C condensation. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#827528
07/30/07 05:36 AM
follow the tube it should come out of the firewall by all of the air condition lines, ill try to look for a picture of it it should look a little something like this, this is one on a TJ ![[Linked Image]](http://i170.photobucket.com/albums/u270/playinmud/acdrain.jpg)
[Re: playinmud]
#827529
07/30/07 05:47 AM
thank you guys, thats what i thought it was. just making sure as every vehicle i have driven with a/c the condensation is always let off near the front of the vehicle.
[Re: DEFBOY35]
#827530
07/30/07 05:52 AM
every car ive seen lets it out behind the passenger front tire, which is where the tube should exit from the firewall, few jeeps have a problem with that tube being clogged or crimped and the AC will actually drain onto the passenger floor
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
