Re: Interesting Kia/Zook similarities.
[Re: Dave Scott]
#827783
10/27/07 01:29 AM
Had a pistol pulled on me for looking under his truck. broke me of that habit! <img src="/forums/images/graemlins/scared.gif" alt="" />
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils http://www.cardomain.com/id/calapooyasMy beater, 03 Land Rover Freelander SE3
[Re: Calappoyas]
#827784
10/28/07 06:08 PM
does anyone here know what transmission exactly is uesd in the manual sportages, i heard getrag mentioned a few times, but need a specific number.
sorry i am useless when it comes to finding this stuff. i just skimmed this entire post and came up empty.
I am in talks with a guy up here at the moment about doing something for us manual guys, he just needs to know what transmission we use.
[Re: DEFBOY35]
#827785
10/29/07 01:59 PM
I am in talks with a guy up here at the moment about doing something for us manual guys, he just needs to know what transmission we use. that's actually the info i was looking for, the best i got was that maybe it is: R15MXD but i cannot gaurantee that even remotely. someone said same as Jeep, i was thinking AX5, but there is no mention of it ever being used in a Sportage. maybe one of the Peugot trannies, but looked for cross-refs and got nada. zip. still looking, though.
95 Sportage w/welded and 5.89 geared dana 44's on 38.5" TSL's.- SADLY SOLD CURRENTLY - 2000 sportage, 5.38 gears, welded diffs, 35" tires, 5.5" lift http://www.cardomain.com/ride/341410
[Re: Dave Scott]
#827786
10/29/07 03:19 PM
Yankee Tim
[Re: Yankee_Tim]
#827787
10/29/07 05:01 PM
that's not specific enough. i guess we could try e-mailing Getrag, but who knows what they'd tell us. either way, the MT is gonna have the same output shaft problem the auto has, 25 spline and 1.125" diameter doesn't match anything. so, let's look for MT's with bellhousings that match the bolt pattern, like one from a Mazda pick-up, up to '93 B2000's and 2200's.
[Re: Dave Scott]
#827788
10/29/07 11:43 PM
Kia Moderator Emeritus
I am in talks with a guy up here at the moment about doing something for us manual guys, he just needs to know what transmission we use. that's actually the info i was looking for, the best i got was that maybe it is: R15MXD but i cannot gaurantee that even remotely. someone said same as Jeep, i was thinking AX5, but there is no mention of it ever being used in a Sportage. maybe one of the Peugot trannies, but looked for cross-refs and got nada. zip. still looking, though. The FSM doesn't help either. All it states is that it's a Getrag gearbox.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
[Re: Dave Scott]
#827789
10/30/07 04:36 AM
that's not specific enough. i guess we could try e-mailing Getrag, but who knows what they'd tell us. either way, the MT is gonna have the same output shaft problem the auto has, 25 spline and 1.125" diameter doesn't match anything. so, let's look for MT's with bellhousings that match the bolt pattern, like one from a Mazda pick-up, up to '93 B2000's and 2200's. Yeah that's the same one I found as I was searching over the weekend. I did see on Getrag's website that they had a developement partnership with Ford. Also got a a part number from a Korean parts web site. but no cross references ever found. <img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: Calappoyas]
#827790
11/01/07 10:46 PM
talked to both of the local dealerships here today, all the one could tell me was that it is a toyota sourced transmission, much like the engine is mazda sourced.
the other dealership did some searching around for me, and so far has come up empty handed. my mechanic buddy there, said he was sure that the 5spd was also a aisin transmission and not getrag.
[Re: DEFBOY35]
#827791
11/02/07 03:58 AM
All I know is when I crawled under it to change its oil GETRAG is cast into the case. Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Everet]
#827792
11/02/07 01:34 PM
All I know is when I crawled under it to change its oil GETRAG is cast into the case. Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> yep, seen that too.
