High voltage #827797 07/30/07 09:59 PM
F
f5000sl Offline OP
Over the last few day my 92 Trooper has been acting funny.
My gauges have been reading extremely high, tach jumps, etc.
Since I've owned the truck, my speedo has always worked on/off, well after about 5 minutes of running.
Anyhow, today my battery was dead (reading 10.2v). So I recharged it, installed it, and it started right up.
My voltage was reading 17-18.9v.
So I disconnected the pos. terminal and the truck still ran, but the voltage varied from 8 - 26volts. Also, my wipers turned on (while in the OFF position) and the idle became really erratic mimicking the voltage changes.
Would this be the voltage regulator?
Is it attached to the alternator?
Can I just change out the regulator?
Any help would be great,
Thanks,
Jay
93 VW Corrado VR6
92 Isuzu Trooper 3.2l (252k & still ticking)
Re: High voltage [Re: f5000sl] #827798 07/31/07 06:34 AM
Egelwolf Offline
My brother recently had a similar problem on his Isuzu. It was found that the brushes were worn real bad. But it can also be the regulator.
'99 Isuzu Frontier (Rodeo) Intercooled 280DT LX
Re: High voltage [Re: Egelwolf] #827799 08/02/07 03:20 AM
CPOM Offline
I would not run it until you fix the problem as high voltage may damage the computer or anything with an integrated circuit (chip). I would guess the voltage regulator on the alternator is bad and since it is probably not serviceable, you might just want to get another one.
CHRIS
98 Amigo, 92 Pup
PHP: 7.4.33 Page Time: 6.150s Queries: 15 (0.006s) Memory: 0.5938 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-10-24 12:20:28 UTC
