more questions on turbos #827830 07/31/07 01:26 AM
O
oopssorry Offline OP
will a crack in the exhaust manifold cause loss of power from the turbo? i had my exhaust manifold off the other day and i noticed it had about a 2 inch long crack in it. you cant hear the exhaust from it but it is still cracked.
1986 toyota pickup rte 4wd sr5 xtracab---bone stock
Re: more questions on turbos [Re: oopssorry] #827831 07/31/07 06:26 AM
mosk Offline
Absolutely. Exhaust leaks in turbo motors are especially bad, because that exhaust is used to spin the turbo. A crack is like another wastegate, only one that can't be closed. Even though the CT20 is a low boost setup, a cracked exhaust manifold will affect how quickly the turbo can spool up.
Now that you're aware of it, I'd suggest getting it repaired or replaced as soon as you can.
-Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: more questions on turbos [Re: oopssorry] #827832 07/31/07 11:21 AM
foxtrapper Offline
Not all cracks leak. As anyone with an old Ford flathead is well aware of. If you're crack doesn't leak, it won't hurt performance. If it does leak, it tends to take away high rpm & high pressure performance.
'97 T-100 SR5
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5962 MB (Peak: 0.6498 MB) Data Comp: Off Server Time: 2026-05-29 15:08:47 UTC
