Page 3 of 10 1 2 3 4 5 … 9 10
Re: Timing Belt [Re: StockRaider] #828232 08/03/07 01:37 AM
FrankR Offline
I think it means that someone has installed:
1) a Stealth/3000GT SOHC engine
or
2) a pair of Stealth/3000GT heads
Now the questions are how much of what has been installed and how to make it work.
Justice, are you paying attention? <img src="/forums/images/graemlins/wink.gif" alt="" />
Frank
Re: Timing Belt [Re: FrankR] #828233 08/03/07 01:39 AM
FrankR Offline
Start by removing the ECU and see what number is stamped on it. The '89 Federal ECU is a #6477.
Frank
Re: Timing Belt [Re: FrankR] #828234 08/03/07 01:54 AM
StockRaider Offline OP
ECU number is 6477
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Timing Belt [Re: FrankR] #828235 08/03/07 02:01 AM
FrankR Offline
Wait a minute - I just looked at the FSM and those sprockets appear to be correct. I also pulled the cover off of my engine and it has the same sprockets.
What I've been looking at in the garage for so long is Bob's engine - which has these sprockets:
Your sprockets are likely correct and the ones on Bob's engine are possibly incorrect.
So, that leaves me to wonder if you have a spun hub in the crankshaft pulley.
Sorry for the confusion - it's been so long since I saw the insides of my engine, I assumed the one I've been working on had the correct sprockets.
Frank
Re: Timing Belt [Re: FrankR] #828236 08/03/07 02:11 AM
FrankR Offline
If the crankshaft pulley hub isn't spun, then you've jumped a tooth on the timing belt.
The only way I know to find out is to strip it down again so you can see the timing marks - or remove the crankshaft pulley and compare it to another one - if you have one handy.
Frank
Re: Timing Belt [Re: FrankR] #828237 08/03/07 02:16 AM
the engine ran fine before tearing it down, just a bad water pump. the marks are all lined up, my compression tester shows its on the compression stroke when the marks are lined up. when I crank it over it would act like it wants to start up for a second and immediately die out.
Richard E
1983 Honda XL600R
Re: Timing Belt [Re: FrankR] #828238 08/03/07 02:27 AM
ha my only extra engine is in my Raider 2 hours away. I really need to get this figured out so I can give it back to him soon. Luckily he has a 2nd car to drive while I do this.
Richard E
1983 Honda XL600R
Re: Timing Belt [Re: StockRaider] #828239 08/03/07 02:32 AM
FrankR Offline
It looks to me like you'll have to tear it back down to check the timing marks against the crankshaft sprocket. If they look ok, the problem is the crankshaft pulley hub and you'll need to get a replacement in order to set the timing correctly.
Since it won't start and run, I suspect the belt has jumped a tooth.
Frank
Re: Timing Belt [Re: FrankR] #828240 08/03/07 02:33 AM
crankshaft pulley hub?? <img src="/forums/images/graemlins/confused.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Timing Belt [Re: StockRaider] #828241 08/03/07 02:47 AM
FrankR Offline
I'm not certain how ours are made, but many are press-fit and some have rubber bushings for vibration damping. I haven't heard of a Montero with a spun pulley, but I wouldn't rule it out.
Odds are greater that the belt slipped a tooth on the sprockets and the crankshaft is out of sync with the valves. Did you follow the FSM procedure for installation?
Frank
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6483 MB (Peak: 0.7559 MB) Data Comp: Off Server Time: 2026-11-02 00:43:49 UTC
