Page 5 of 10 1 2 3 4 5 6 7 9 10
Re: Timing Belt [Re: StockRaider] #828252 08/03/07 06:40 AM
52degrees Offline
Did you at any time pull the distributor?
KG6VNX
Re: Timing Belt [Re: 52degrees] #828253 08/03/07 07:09 AM
StockRaider Offline OP
no, i didn't touch the distributer aside from removing the cap.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Timing Belt [Re: StockRaider] #828254 08/03/07 07:29 AM
52degrees Offline
Then quit messing with it. It's likely not timing related. All your pictures look good. Don't worry about the crank pulley marks, they are irrelevant at this time.
Are you making sure that things like the MAF connector are back in and secure? I think it can go in upside down, or if it's not fully seated the engine won't start.
Is there a crank sensor? If that were disconnected you won't have spark or fuel injector pulse.
BTW, I check for injector pulse using a pair of cheap LEDs. I plug both into the injector harness pointing opposite directions and crank the engine. Simple and extremely cheap.
For the spark, I guess you could have an assistant hold the dizzy end of the coil wire while you crank it <img src="/forums/images/graemlins/lol.gif" alt="" />
My bet is on the MAF connection though.
KG6VNX
Re: Timing Belt [Re: 52degrees] #828255 08/03/07 08:01 AM
I am about to start the final (fingers crossed) assembly, I will definitely check all wiring harness connections.
Richard E
1983 Honda XL600R
Re: Timing Belt [Re: 52degrees] #828256 08/03/07 08:02 AM
I will let the owner try that one... <img src="/forums/images/graemlins/evil.gif" alt="" /> I am not even being paid for this! <img src="/forums/images/graemlins/ignore.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Timing Belt [Re: StockRaider] #828257 08/03/07 08:34 AM
87Montero Offline
[Linked Image] <img src="/forums/images/graemlins/confused.gif" alt="" />
That doesn't look right. It should be at the 0* TDC mark on that cover, right? and when you hook up a timing gun.. That's when you will find it the 15 degrees BTDC right?
Someone tell me I'm wrong but that's not how my motors look when I put them back together!
Re: Timing Belt [Re: 87Montero] #828258 08/03/07 09:28 AM
I just got done putting it back together to the point where I can actually start it. It trys its best to start but immediately dies. I am uploading the audio now.
Richard E
1983 Honda XL600R
Re: Timing Belt [Re: StockRaider] #828259 08/03/07 09:40 AM
God I love my Creative Zen, the sound file is very clear only using the on board mic.
**Used Rapidshare to upload, Might be blocked on work computers**
Engine Almost Starting
Richard E
1983 Honda XL600R
Re: Timing Belt [Re: FrankR] #828260 08/03/07 12:36 PM
Y
yankneck696 Offline
The Stealth & 3000 GT sprockets align perfectly. I did a bench comparison when I was assembling mine.
I used the Stealth cogs in mine.
Looks to me like he is off a tooth. I would try lifting it a bit & rotating 1 tooth to check.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: Timing Belt [Re: yankneck696] #828261 08/03/07 01:05 PM
Y
yankneck696 Offline
Things to check:
1. When at TDC, put balancer & plastic cover on... Does it line up to 0 deg or 15 deg?
If 15 deg, alignment of belt or slipped balancer pulley... If not, #2
2. When you install dist, are you aligning all marks like you are supposed to? Is it seating all the way down flange to base?Is the adjuster stud in the center of adjustment slot? If not, keep trying... It truly seems to be off 1 tooth. I had this issue till I found the dist alignment procedure. If not, #3
3. Check & recycle all plug connections with di-electric grease. Might be a bit of corrosion in there. If not #4.
4.... Scare the bejesus out of it with a cutting torch... Mine mysteriously ran fine after that ( actually found loose plug).
Ed
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6499 MB (Peak: 0.7587 MB) Data Comp: Off Server Time: 2026-11-02 12:29:22 UTC
