Page 6 of 10 1 2 … 4 5 6 7 8 9 10
Re: Timing Belt [Re: yankneck696] #828262 08/03/07 01:16 PM
FrankR Offline
The sound file sounds like it starts, just doesn't run..... gott fuel?
Frank
Re: Timing Belt [Re: 87Montero] #828263 08/03/07 02:28 PM
sparkem Offline
[Linked Image] <img src="/forums/images/graemlins/confused.gif" alt="" />
That doesn't look right. It should be at the 0* TDC mark on that cover, right? and when you hook up a timing gun.. That's when you will find it the 15 degrees BTDC right?
Someone tell me I'm wrong but that's not how my motors look when I put them back together!
That mark should be on 0, not on the 15.
Re: Timing Belt [Re: sparkem] #828264 08/03/07 03:17 PM
Oyaji_Jon Offline
That's what I was referring to when I said he should zero the crank, but if you look at the notch on the crank timing gear, it's right on...
I'm confused...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Timing Belt [Re: Oyaji_Jon] #828265 08/03/07 03:22 PM
sparkem Offline
I'm confused...
I did not know there was a notch on the timing gear. I have always used the pully notch and put it on zero.
Re: Timing Belt [Re: sparkem] #828266 08/03/07 04:04 PM
Oyaji_Jon Offline
I'm confused...
When you put the belt on, how do you see the mark on the crank pulley and the timing cover. It's disassembled. I think the gear notch and pulley mark should line up though, correct?
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Timing Belt [Re: StockRaider] #828267 08/03/07 04:06 PM
Oyaji_Jon Offline
The crank timing gear notch...
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Timing Belt [Re: Oyaji_Jon] #828268 08/03/07 04:18 PM
sparkem Offline
I put the new belt on and put the pulley on. Then I put the timing belt cover plastic thing on and line up the mark on the pulley. Then take the cover off and line up my cams and put the belt on.
Now thinking about it, isnt there a dimple or something like on the cam sprocket?
Re: Timing Belt [Re: sparkem] #828269 08/03/07 04:59 PM
Oyaji_Jon Offline
Yes, there is. If you look up a few posts, you can see all of those marks. StockRaider took pictures of every reference notch. You have to align all three (each cam mark and the crank gear notch) to achieve proper timing when you put the belt on.
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Timing Belt [Re: FrankR] #828270 08/03/07 05:01 PM
StockRaider Offline OP
Frank
I believe it has fuel. I am starting to wonder if it has an ample supply to support after starting. My friend was messing with the fuel filter while I was doing the timing belt. So I will definitly check it all out.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Timing Belt [Re: StockRaider] #828271 08/03/07 05:16 PM
Mad_Scientist Offline
I just lined up the crank timing gear notch and then the cam sprockets, then put the belt on. However, I don't have dizzy timing to worry about... <img src="/forums/images/graemlins/confused.gif" alt="" />
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6469 MB (Peak: 0.7724 MB) Data Comp: Off Server Time: 2026-11-02 09:05:09 UTC
