Page 8 of 10 1 2 … 6 7 8 9 10
Re: Timing Belt [Re: hazy_daze] #828282 08/06/07 01:17 AM
StockRaider Offline OP
I no longer hear the fuel pump engaging. I am wondering where a relay or fuse would be. I dont see one in the dash and I replaced the MPI fuse. Still nothing. Can the fuel pump go bad THAT suddenly? Wait, I dont need to ask that... If the fuel filter is blocked somehow will the pump cut off to keep itself from burning up? I believe I have it knocked down to being a fuel issue.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Timing Belt [Re: StockRaider] #828283 08/06/07 02:41 AM
FrankR Offline
I think it's fuel related also, but it could be an electrical control function of the fuel system.
First, check to see if your pressure washing blew the vacuum hose off the fuel pressure regulator.... it's at the rear of the passenger side fuel rail.
Next, connect the battery to the fuel pump drive terminal and see if the pump runs. Then check the control relay.
Also, check for power on the ignition switch in the "RUN" position.
Frank
Re: Timing Belt [Re: FrankR] #828284 08/06/07 02:54 AM
where is the drive terminal located?
Richard E
1983 Honda XL600R
Re: Timing Belt [Re: StockRaider] #828285 08/06/07 02:58 AM
FrankR Offline
Passenger side, behind the sidewall kick panel.... Do you need the FSM MPI section? If so, I can send it via email as a .pdf file.
Frank
Re: Timing Belt [Re: FrankR] #828286 08/06/07 03:04 AM
Thanks but I found my copy. I can't believe how much of a PITA this has turned into. I still have my share of problems to fix on my Raider as it is. <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Timing Belt [Re: StockRaider] #828287 08/06/07 12:03 PM
FrankR Offline
I can't remember if it's possible to install the fuel filter reversed. Don't those filters have a directional arrow stamped on them? I'd recheck that.
Frank
Re: Timing Belt [Re: FrankR] #828288 08/07/07 07:16 AM
anyone have a picture where the drive terminal is located? I have 2 plugs in that area.
Richard E
1983 Honda XL600R
Re: Timing Belt [Re: StockRaider] #828289 08/07/07 12:02 PM
G
generation_one Offline
no picture but C-42 appears to be a single wire male connector.black with white stripe . should be the same wire from the pump.
looking at 8-56 of fsm (MPI diagram) you can also just put 12 volts to the pump and it is the same as putting positive to the drive terminal
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Timing Belt [Re: StockRaider] #828290 08/07/07 06:52 PM
8
89IsMine Offline
Mine was taped back against the wire bundle with some blue tape. It was pretty high up under the dash, well above the ECU and relays. Sorry, no picture...
Eric W.
Re: Timing Belt [Re: 89IsMine] #828291 08/08/07 07:49 PM
Pump turns on when the engine first starts. stays on for a second after dying out. I am really starting to run out of steam working on this thing... <img src="/forums/images/graemlins/frown.gif" alt="" />
Richard E
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6451 MB (Peak: 0.7689 MB) Data Comp: Off Server Time: 2026-11-02 04:40:35 UTC
