Page 3 of 4 1 2 3 4
Re: '86 22re strange misfire/studder [Re: AZcoma] #828362 09/08/07 01:13 AM
4Crawler Offline
W/ no vacuum on the FPR, you get maximum fuel pressure all the time, instead of having it lowered at idle. Could be you have marginally low fuel pressure (a pressure gauge would confirm that) or the injectors are clogged up and need the extra pressure to flow enough fuel (a good cleaning would fix that).
Re: '86 22re strange misfire/studder [Re: 4Crawler] #828363 09/08/07 05:34 PM
A
AZcoma Offline OP
Best/easiest way to check fuel pressure??? pull line at cold injector? Could very well be injectors as well since they've been running for >21 years untouched other than gas tank fuel injector cleaner now and then. Tonight, before heading home from work, I'm going to remove the vauum line to the FPR and plug it just to see how well it runs under driving conditions...
'86 4x4 SR5 22re 5" lift 35" BFG's and 5:29 gears.
'05 4x4 DC Tacoma TRD Sport
Re: '86 22re strange misfire/studder [Re: AZcoma] #828364 09/10/07 08:28 PM
sanuoff Offline
how long did your truck sit while motor was being rebuilt?
mine sat for almost 2 months.
Re: '86 22re strange misfire/studder [Re: sanuoff] #828365 09/13/07 11:16 AM
sanuoff Offline
well i gota chance to check my fuel pressure, 43psi at idle and when i blip the throttle it would shoot up to 48psi, when i would hold up the rpm's and let throttle plate shut for high vacuum it would drop as low as 30 but go right to 43 when idle droped.
so i hope to check out ignition in next day or so. is anyone else had any other any luck checking that out?
Re: '86 22re strange misfire/studder [Re: sanuoff] #828366 09/13/07 05:02 PM
Frank Torres Offline
I've been reading this thread and no mention of verifying the timing off idle and at part throttle.
Timing should advance when throttle is opened and hold (not jump around).
Did you do any splicing of the wire harness?
anyway just throwing a bone...
good luck
1991 FJ 80 Land Cruiser for fun.
1998 GS300 for the wife
1998 GS400 for me
1991 Supra SOLD
1986 4Runner 335k miles-22re EB inside.SOLD
Re: '86 22re strange misfire/studder [Re: Frank Torres] #828367 09/13/07 06:06 PM
G
GOI87 Offline
I would Also check all of the Ground Connections, Especially the one that attaches to the Intake maniflold. If I Recall, that one grounds the injectors to make them fire. Also make sure your TPS is working and is "set" right. If you put a timming light on it and see where it is at idel, then give it alittle bit of gas it should instantly advace. When my TPS wasn't set right it the Timming would retard for a split second, then advance. I would also make sure that all of the EGR components do not have any exhaust leaks.
I'm just trying to come up with stuff that hasn't been mentioned that might help, or lead somewhere <img src="/forums/images/graemlins/zombie.gif" alt="" />
Good luck,
GOI <img src="/forums/images/graemlins/kewl.gif" alt="" />
87 Toyota 4Runner-RV Head, Custom Grind Cam, Doug Thorley Header, Keith Black Pistions, 2 1/4" Magnaflow cat, Dynomax Exhaust
2003 Toyota Matrix XRS-Injen CAI
Re: '86 22re strange misfire/studder [Re: GOI87] #828368 09/13/07 11:35 PM
A
AZcoma Offline OP
Good luck,
I did verify timing with jumper in place. Set it at 8 degrees BTC. This is the recommendation for the cam in place. Now, I didn't check it without the jumper in place to see if it advances quickly off of idle (partial throttle). I can try this test.
Re: '86 22re strange misfire/studder [Re: AZcoma] #828369 09/14/07 02:19 PM
sanuoff Offline
i have the base timing set at 8 degrees, and it is advancing as soon as throttle is snapped.
I have 3 grounds one on head, one on block, and one on the intake.
I also notice that is is really only happening in a certian rpm range 2200-2900, thats about were i am when i really can feel it. It seems over 3000 i can not seem to feel it.
I am wondering if the cam i choose has anything to do with this, the cruising range for it is supposed to be 3000-3600.
Re: '86 22re strange misfire/studder [Re: sanuoff] #828370 09/14/07 10:20 PM
A
AZcoma Offline OP
3 grounds for me as well. Two are combined on the intake manifold grounded at the connection that holds the brace (black bar) and then one on the Block of the engine. I'll ohm them out as well. There is one other thing I stumbled across in the Toyota manual and that's the fuel cut-off signal that occurs when letting off of the gas the ECU will shut off fuel to the injectors @ 1500rpm. Any chance this might be an issue?? Normal driving you'll never know it's there (under load or cruising down the freeway at 70mph... One of these days.... between all of our heads put together.... this WILL get resolved.... I hope!
Re: '86 22re strange misfire/studder [Re: AZcoma] #828371 09/21/07 12:41 PM
sanuoff Offline
Which lce cam did you choose to go with?
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6441 MB (Peak: 0.7539 MB) Data Comp: Off Server Time: 2026-11-19 05:28:53 UTC
