Re: bent axel
[Re: cktoy]
#829130
08/08/07 08:53 PM
Talk them down, or a deal on the springs too, if yours are toast.
Re: bent axel
[Re: Staceman]
#829131
08/08/07 09:14 PM
MAN IT SEEMS LIKE THERE OUGHT TO BE A WAY TO FIX IT IT IS ONLY out about 3/4".this stock efi truck doesnt run nearly as good as my old one.I allways wondered if I had any more power than stock,now I know.the new parts will have to wait for pay day.I hope my locker is not damaged.
oh what a feeling: #1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered #2 86 sr5 4x4 efi parts truck #3 87 2wd parts truck 84 supra yard art
Re: bent axel
[Re: cktoy]
#829132
08/08/07 09:45 PM
Might be worth checking the axle farther. For example, measure tire-tire front and rear and see if the tires are parallel or not. If not, then the housing is bent. If they are still parallel, then you might have shifted the axle under the springs or something like that. Easy enough to loosen the u-bolts and inspect that area and see what is up.
Re: bent axel
[Re: 4Crawler]
#829133
08/09/07 05:06 PM
thanks I have taken the u bolts loose,cant see any thing broke,but I have not checked tires front to rear for parallel.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6078 MB (Peak: 0.6637 MB) Data Comp: Off Server Time: 2026-06-17 16:41:04 UTCValid HTML 5 and Valid CSS
