bent axel
#829120
08/06/07 09:05 PM
I was in a wreck today.My rear pas. wheel took the brunt of the hit,I think the axel is bent.Can these be repaired or straightened out
oh what a feeling: #1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered #2 86 sr5 4x4 efi parts truck #3 87 2wd parts truck 84 supra yard art
Re: bent axel
[Re: 4Crawler]
#829122
08/07/07 12:14 AM
thanks,I cant see any damage to anything outside,the wheel sits about 3/4" further back than it should.it drives ok .any good way to check the housing?
Re: bent axel
[Re: cktoy]
#829123
08/07/07 12:32 AM
Lift the tire in the air and spin it. If it wobbles, the axle is bent. If it is only shifted, my guess is a sheared off center pin and the axle and u-bolts slid off center of the springs.
Re: bent axel
[Re: 4Crawler]
#829124
08/07/07 01:09 AM
Like Roger said, check the center pin in the spring. They are designed to shear on hard impact. If that is what it is, replace and torque the U-bolts down on both sides to 90 ft lbs.
"Serenity through Sobriety"
Re: bent axel
[Re: OOP'S]
#829125
08/07/07 01:49 PM
thanks guys,this site is the best tool in the box
Re: bent axel
[Re: cktoy]
#829126
08/08/07 03:14 PM
Im pretty sure my housing is bent.Anybody know where I can get another one.I just bought an 86 single cab with efi,but hate to tear it apart cause it runs good and only has 160k on it.MAN THIS SUCKS <img src="/forums/images/graemlins/angry.gif" alt="" /> it was a hit and run to top it off.it looks like the bend is in the very end of the housing ,theres no wobble when I spin the tire.the rear of my wheel sits 3/4" closer to the spring than the front.looks like the spring is bent too.the pin doesnt look to be sheered
Re: bent axel
[Re: cktoy]
#829127
08/08/07 04:04 PM
Here you go dude. From car-part.com I'm not sure if this is close to you in Tn or not. 1987 Axle Housing Only Toyota Truck -*UNDER *437-58042* 3318 $75 Bolivar Salvage & Auto Parts USA-TN(Bolivar) E-mail 1-800-748-9185 / 1-731-658-9468 1987 Axle Housing Only Toyota Truck -*TRANS *437-58042* 3156 $75 Bolivar Salvage & Auto Parts USA-TN(Bolivar) E-mail 1-800-748-9185 / 1-731-658-9468
Re: bent axel
[Re: Staceman]
#829128
08/08/07 04:07 PM
Here's a few in the Carolinas. 1987 Axle Housing Only Toyota Truck 4X4,MT A 960042 $75 Roper Motor Company USA-NC(Grover) E-mail 1-704-739-1396 / 1-800-222-7931 1987 Axle Housing Only Toyota Truck 4X4,BARE 060458 $75 Graves Auto Salvage USA-SC(Aiken) E-mail 1-803-648-9012 / 1-800-922-8849
Re: bent axel
[Re: Staceman]
#829129
08/08/07 05:48 PM
cool,boliver is not to farr to go for truck parts.THANKS
