Page 1 of 4 1 2 3 4
ARB Bumper & Winch Mounted #829212 08/07/07 03:49 AM
Scottie2113 Offline OP
I put a 12,000 lbs milemarker winch on it, installed my headlight washers (Angelo: I see why you need PVC pipe now; thanks! <img src="/forums/images/graemlins/kewl.gif" alt="" />) installed my turn signal kit, outside temperature sensor, factory fog lights, winch control box, and that's about it. The new frame horns were fabricated out of 3/8" plate with heavy duty spacers and hardened washers in between. I mounted the bumper to the truck with a total of 6 bolts, 3 on each side. engauge/free-spool lever is easily accessible through bull bar opening. I have to say, I really like the way it turned out. I like the idea of having my head light washers back. after not having them for close to 9 months, they are just the coolest thing going on my bumper right now. everyone asks "what are these things?" and when i tell them they want to see them work. its like no one ever saw headlight washers before. enjoy the pics.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: ARB Bumper & Winch Mounted [Re: Scottie2113] #829213 08/07/07 04:05 AM
NathanC Offline
Man those ARB's are sexy!! Sadly, I don't think I could bring myself to buy one <img src="/forums/images/graemlins/baby.gif" alt="" />.
That looks great! <img src="/forums/images/graemlins/cheers.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: ARB Bumper & Winch Mounted [Re: NathanC] #829214 08/07/07 04:12 AM
LandRaider Offline
Looks JUST like mine!! I like it!!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
I wish my headlight washer were still in exhistance. they're gone like 3 motor swaps ago. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: ARB Bumper & Winch Mounted [Re: Scottie2113] #829215 08/07/07 04:12 AM
89montero Offline
looks awesome! Wish they made that style arb for a Gen 1
1989 Montero 4dr V6 3.0l
Re: ARB Bumper & Winch Mounted [Re: NathanC] #829216 08/07/07 04:18 AM
Oyaji_Jon Offline
Very nice! Your rig's lookin' great!
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: ARB Bumper & Winch Mounted [Re: Oyaji_Jon] #829217 08/07/07 04:25 AM
DavidG Offline
Very nice indeed <img src="/forums/images/graemlins/kewl.gif" alt="" />
1997 Montero SR
<a href="www.georgiaoverland.com" target="_blank">www.georgiaoverland.com</a>
Re: ARB Bumper & Winch Mounted [Re: DavidG] #829218 08/07/07 05:09 AM
Also, does anyone know why there are 4 cables going to the winch motor? I would think there would be only 2, neg and pos and they switch polarity to switch direction. my winch has one ground and 3 cables going from control box to motor. can anyone explain the circuit to me? Also, inside the control box are 2 solenoids, each with 4 power terminals and 2 signal (activation) terminals. there is a small circuit board inside the control box as well as inside the hand held remote control that plugs into the control box. there are 4 wires going from control box to remote (gnd, pwr, data, clk) so the 2 circuit boards can talk to each other. I want to wire up an in cab switch, but don't know how the solenoids work inside the control box and also fear that it may 'fry' the circuit boards if its not compatible with such a setup. I was thinking as a last resort to use the remote cable and circuit board to wire up my in cab switch by taking the 3 leads off the board that go to the in and out buttons on the remote and wiring them directly to my switch utilizing the original circuit boards as intended just without the original buttons on the remote. does anyone have any other ideas? how do the solenoids work and what do the cables do? can I wire it up directly to the soleniods? like i said there are only 2 solenoids in the box, each with 6 leads (4 heavy duty connections and 2 light duty connections most likely used to activate the solenoids)
Re: ARB Bumper & Winch Mounted [Re: Scottie2113] #829219 08/07/07 05:43 AM
LandRaider Offline
There are different windings in the motor for forward and reverse. Thats why you have 3 fat cables on the winch motor. 1 ground, and 2 powers.
As far as wiring the soloniods up you basically have a forward, and a reverse one.
The MM setup prob has a switched ground, and has constant 12 volts on the soloniods, so all you have to do is ground the other side of the soloniod, and it will energize.
very simple really.
AND you can put that bumper on a Gen1 Just as easy as it goes on a US Gen 2. My ARB is a Gen2. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: ARB Bumper & Winch Mounted [Re: LandRaider] #829220 08/07/07 05:46 AM
my MM winch has 4 fat cables going to the motor (1 ground and 3 from the control box) what do you make of that?
Re: ARB Bumper & Winch Mounted [Re: Scottie2113] #829221 08/07/07 05:49 AM
LandRaider Offline
Possibly a brake winding?
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6516 MB (Peak: 0.7766 MB) Data Comp: Off Server Time: 2026-06-05 16:33:17 UTC
