Page 3 of 4 1 2 3 4
Re: ARB Bumper & Winch Mounted [Re: lordtrunks] #829232 08/08/07 02:52 AM
justice Offline
I noticed your mm 12k is mosefet mine wasn't it just had 2 poppers inside the control box and it was screwed together not rivited. On another note when it took my mm gear box apart the inside cover said t-max on it.
Yea I noticed mine said T-max on the inside too.
Re: ARB Bumper & Winch Mounted [Re: justice] #829233 08/09/07 02:02 AM
looks great! but it looks like it's touching the body up against the valance.
Re: ARB Bumper & Winch Mounted [Re: TOASTY] #829234 08/09/07 03:59 AM
Angelo Offline
yeah, kinda looks that way, you need atleast 1/2" of space cause the frame will flex a little and when it does, its going to eventually knock those flares loose a bit.
Another thing I noticed, If the guy that fabbed up your frame horns used the exsisting frame and just built off of it, I might be worried. Those frame horns are strong, but def not designed to take anymore stress like a winch pulling at max force. Maybe if he "boxed" in the frame with a plate in the front so you cant see inside it, might help out greatly.
My buddy had cut mine off completely past the factory tow hooks and attached it back from there. You want a smooth appoarch angle and nothing to hold you up if it gets close to those tow hooks. Just something to think about.
Angelo
Re: ARB Bumper & Winch Mounted [Re: Angelo] #829235 08/09/07 05:53 PM
bretwalda Offline
Looks great. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I thought you had the 2.5 body style. Mine didnt have the light mounts (among other things). Did you have to drill out for the light washers?
concreteprinter.com
Re: ARB Bumper & Winch Mounted [Re: bretwalda] #829236 08/09/07 08:39 PM
Scottie2113 Offline OP
yes, you drill and hole through the bumper and use PVC pipe to mount them from underneath.
thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: ARB Bumper & Winch Mounted [Re: Angelo] #829237 08/10/07 01:12 AM
Angelo
or blow out a headlight, impact shock will transmit into the glass housing and shatter it.
Re: ARB Bumper & Winch Mounted [Re: TOASTY] #829238 08/21/07 07:21 PM
Brianawd Offline
Sorry to bring this back from the dead, but I am getting ready to order my ARB front bumper and wanted to know how long it takes to get it here.
92 Galant vr4 11.17at132mph
98 Montero 2.5"lift,33/10.50/15,15x8procomp wheels.
trail-gear rock sliders,ARB front bumper,Warn m8000 winch. Piaa lights.
Re: ARB Bumper & Winch Mounted [Re: Brianawd] #829239 08/21/07 07:50 PM
Angelo Offline
Could be as soon as a month, but u usually takes around 2 months
Re: ARB Bumper & Winch Mounted [Re: Brianawd] #829240 08/21/07 08:52 PM
well, in my case, if you are going through 4wheelparts, it will probably take 3 months. then if fedex loses it, it will be another 3 months for them to re-ship another one from aussieland. then if 4wheelparts forgets to process the claim through fedex who lost the first bumper, add another month, so in total for me it was about 8 months. but if all goes well for you, 2-3 months.
Re: ARB Bumper & Winch Mounted [Re: Scottie2113] #829241 08/21/07 09:29 PM
Banacheq Offline
I just contacted sportztrailers.net and they said they have to order the bumper from Florida and that it would only take 5 extra business days. This is for ARB part #3434020 for a '91-'00 Deluxe Winch Bar. Here's a link to the site and the page that has the bumper: http://app.vendio.com/storefront?vi...sid=288192&mode=1&pnum=2
Price seems fair and the cost for shipping to CA was quoted as $80. I assume that's ground of course.
I hope to get mine sometime soon myself.
~Banacheq
'97 SR | K&N air filter | BFG ATs 33x10.50R15 on stock wheels | more to come...
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6449 MB (Peak: 0.7529 MB) Data Comp: Off Server Time: 2026-06-22 06:04:46 UTC
