Re: some concerns with my gen 1 few things i'm not sure of [Re: blackmage] #829382 08/11/07 02:34 AM
Basically, what FastEddy means is: don't drain something you can't refill. The plug he's referring to is on the side of the transmission, and there's another one on the side of the transfer case. They have square heads as I recall. Simply unscrew them first. It will be fairly obvious once you crawl underneath. This is where you will have to add the new fluid, and it has to be pumped up there because there's no way to pour it in as the body and frame of the truck are in the way. I bought a little plastic pump that screws onto the bottle of 85W-90 gear lube and I just put it in the fill hole and pump until it runs out of the same hole, meaning it is full. It's messy. The stuff stinks. Fair warning.
Re: some concerns with my gen 1 few things i'm not sure of [Re: JohnnyBfromPeoria] #829383 08/11/07 07:52 AM
blackmage Offline OP
where can i get this little plastic pump? What would work? what if found like a water bottle nozzle like u no for cleaning n stuff windex example break off the little thing that makes it spray and pretty makes it leak out ? do i have to drain the transfer case and transmission or they one in the same i could probably look in my Haynes book and find out lol
and 80 90 w the oil ima need to get
Re: some concerns with my gen 1 few things i'm not sure of [Re: blackmage] #829384 08/11/07 11:45 AM
hazy_daze Offline
Balkamp (a NAPA brand) makes something really neat for this purpose. It looks like a cross between a grease gun and a syringe. It's about $15. I'll post a part # when I get to work.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6023 MB (Peak: 0.6558 MB) Data Comp: Off Server Time: 2026-06-20 20:24:45 UTC
