Re: 91 isuzu trooper trans light blink [Re: nrb1218a] #829786 08/30/07 04:36 PM
rodeorat Offline
Check all your grounds. I had trouble with my 92' Rodeo's trans going into limp mode. Turns out part of the TCM grounded at the oil sending unit. Also someone prior to my buying it had left off the ground wire at the back of the intake manifold. When I bought it I was told it needed a torque converter. Fixing the grounds cured my problems.
GOD Said It, I Believe It, That Settles It.
Re: 91 isuzu trooper trans light blink [Re: nrb1218a] #829787 09/07/07 09:49 PM
N
nrb1218a Offline OP
I just want to update you guys on the status of my transmission problem.
The problem has been resolved. I basically removed some
transmission fluid and then I added a lucas transmission fix. The cure did not happen overnight but after 50 to 100 miles I noticed that the transmission problem happens not as frequent as before then the problem is totally gone.
I never thought that this product is that effective until now. I read it in one of the 4x4 forums and I thought its a ridiculuos suggestion but it actually works.
Re: 91 isuzu trooper trans light blink [Re: rodeorat] #829788 09/10/07 07:51 PM
N
nrb1218a Offline OP
Thanks rodeorat. I did check the ground and everything seems to be fine.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5996 MB (Peak: 0.6528 MB) Data Comp: Off Server Time: 2026-07-09 21:35:10 UTC
