I rescued an 89 trooper, now what.. #830557 08/13/07 03:41 AM
subieracer Offline OP
picked up an 89 trooper 4cyl w/auto tranny for $600 but its been sitting for almost two years.
other than changing the oil and battery what else should i do? it had very little gas when parked, so do i really need to drain out the old gas or can i just add come heat to whats in there and then dump some fresh gas on top?
thanks..
also, where is the best place to get a new radiator?
Re: I rescued an 89 trooper, now what.. [Re: subieracer] #830558 08/13/07 04:10 AM
strawmyers Offline
Isuzu Moderator
Adjust the valves
drain/flush/refill the cooling system at least twice
Change all filters (fuel, oil, air, tranny)
drain and refill all fluids
check the brakes
repack the wheel bearings
normal tune-up stuff (cap, rotor, plug wires, plugs)
Spend a bunch of money at www.independent4x.com and put some dents in it! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Sean Strawmyer
Re: I rescued an 89 trooper, now what.. [Re: strawmyers] #830559 08/13/07 04:53 AM
yep thats why i bought it, i race rally cars during the summer so i need to get my wheeling fix in the winter. smile ok, but what about the gas? think whats in the tank will be fine?
Re: I rescued an 89 trooper, now what.. [Re: subieracer] #830560 08/13/07 04:57 AM
lttlbddy Offline
If it runs rough it could be the gas. Try it and see.
Re: I rescued an 89 trooper, now what.. [Re: lttlbddy] #830561 08/15/07 06:56 AM
whoo hoo!!! so i tried to jump start the trooper today, and my rallycar battery was barely strong enough to get it to start, i also found out i have a really loud car alarm with no key fob, haha.. but she started!!! so then i went about replacing the battery and radiator, which is a pain in the ass if anyone was wondering. got everything back together only to find that the auto tranny cooler lines are bigger on the new radiator so now i need to get some new hose, but after that everything should be great...
PHP: 7.4.33 Page Time: 1.647s Queries: 15 (0.005s) Memory: 0.6042 MB (Peak: 0.6689 MB) Data Comp: Off Server Time: 2026-11-16 06:52:19 UTC
