Re: Much needed help [Re: highvan] #830691 08/15/07 10:35 PM
W
wytee Offline
its easy to pull the thermostat and check it out but if your losing fluid and there is no leak then not to sure what that would be.
"IM THERE BUDDY"
Re: Much needed help [Re: wytee] #830692 08/16/07 02:38 AM
highvan Offline OP
I got the old one and it was stuck shut, so i got a new one, put it in and let it run a bit, seems to be fixed <img src="/forums/images/graemlins/kewl.gif" alt="" />
www.warrencountyimports.com
Calling all creative people, could be an easy $30, no joke! http://carandturcktalk.mywowbb.com/forum11/7.html
Re: Much needed help [Re: highvan] #830693 08/24/07 07:50 AM
DRTDEVL Offline
For the speedo, take the cable back off of the t-case and attach it to a drill. Run the drill in reverse and see if the speedo moves.
If it moves, you need to replace the speedo adapter gears (about $30 at the dealer). 1 bolt holds the adapter, and then it all slides right out.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5990 MB (Peak: 0.6521 MB) Data Comp: Off Server Time: 2026-06-20 18:53:37 UTC
