Help - Strange noise when front tire drives over curb #830953 08/15/07 04:21 PM
KarlC Offline OP
I did a few searchs on this, but counld not find any thing. When one wheel drives over a curb I hear a very loud creaking noise. What do you think ?
San Diego CA
Re: Help - Strange noise when front tire drives over curb [Re: KarlC] #830954 08/15/07 04:42 PM
stony-man Offline
My money is on it needing a good greasing. There are a bunch of zerks under the front end. Brandon can testify to how loud/much my front was squeaking when I hit bumps, and a good greasing silenced it completely. Otherwise, it could be a number of different frond end parts that are worn. I'll let someone qualified suggest further info.
Re: Help - Strange noise when front tire drives over curb [Re: stony-man] #830955 08/15/07 04:48 PM
hazy_daze Offline
Mine is well-lubed and still has a creaking at full lock on uneven surfaces. Still haven't figured it out. But nothing is broken or severely worn, so I live with it. That said, greasing the front end would be a good place to start <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Help - Strange noise when front tire drives over curb [Re: hazy_daze] #830956 08/15/07 04:51 PM
Hint, Steering stops.
Re: Help - Strange noise when front tire drives over curb [Re: OldColt] #830957 08/15/07 05:01 PM
hazy_daze Offline
Ok, that makes sense. Thanks Charlie. Is there any lubrication or hacking needed on those?
Re: Help - Strange noise when front tire drives over curb [Re: hazy_daze] #830958 08/15/07 05:42 PM
justice Offline
I but a dab of heavy grease on the stops..quiets them down for a while..
Re: Help - Strange noise when front tire drives over curb [Re: justice] #830959 08/15/07 07:50 PM
hazy_daze Offline
Sweet, thx Justice. I'll try that.
Re: Help - Strange noise when front tire drives over curb [Re: hazy_daze] #830960 08/16/07 03:18 AM
52degrees Offline
Upper ball joints on t-bar cranked rigs makes that noise too. At least, that's what I've been told (by Ray, who isn't a mechanic <img src="/forums/images/graemlins/lol.gif" alt="" />).
KG6VNX
Re: Help - Strange noise when front tire drives over curb [Re: hazy_daze] #830961 08/16/07 02:40 PM
sasnydley Offline
There is a turn stop that slides up and down when at full crank and you hit a bump. This has a hard plastic piece that wears out easily. So when at full crank you get this horrendous sweak!!!. I periodically squirt a gob and black silicone adhesive on the bolt and slide point which helps alievate this.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6292 MB (Peak: 0.7158 MB) Data Comp: Off Server Time: 2026-06-03 10:46:49 UTC
