Brake & battery light stays on need help #831507 08/19/07 05:12 AM
MnMsToY Offline OP
I'm posting this for a buddy. He has already replaced the Alternator and voltage regulator. Dash lights still stay on. He also replaced the Master cyl. cap that has the wires on it.
Mike
I have a 82 Toyota with a 22r engine. The other day, both the brake light and the battery light both came on at the same time. I've read that this is a sign that the alternator is starting to go bad and or the skinny wire coming off the positive battery(goes to alternator) post could be corroded needing cleaning or the whole wire it self could be bad causing both battery and brake lights to come on.
Has anyone had this experience with their toy or heard of this happening?
Also does anyone know where the "alt fuse" is at. Or the "alt wire junction box" is at. Or are these things not on a 82 toy. I read these things should be checked also.
Thought I'd throw this out there at the same time that I'm researching it and pawing around the engine of my new to me toy.
Any help would be appreciated. Thanks
1980 Toy, Dovetail, Chevy 60/14, 5.13 gears "Wheeling isn't cheap anymore"
http://www.texas4x4.org/gallery/MikesToyota
Re: Brake & battery light stays on need help [Re: MnMsToY] #831508 08/19/07 05:44 AM
stock87 Offline
I think there's a relay in the fuse box that controls the light too. May check that. Charge light relay or something.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Brake & battery light stays on need help [Re: stock87] #831509 08/19/07 06:41 AM
MnMsToY Offline OP
I'll have him look at the three relays that I know of. Kick panel and two above the steering column.
Mike
Re: Brake & battery light stays on need help [Re: MnMsToY] #831510 08/20/07 02:05 AM
kewlynx Offline
Mike, I'm not sure where that charge light relay is at; was helping someone in the back room on that for his 81.
On the B+ line; it goes across from the main fuse box via the core support wire bundle. There's a little black plastic box on the driver's fender; it's a terminal lug; from there it goes to the B+ on the alternator harness. This is set up this way to allow you to remove the alternator harness without tearing the rest of it down.
Also inspect the wire harness at the plug; these older rigs start experiencing insulation failure; don't want to be smoke checkin' anything! <img src="/forums/images/graemlins/scared.gif" alt="" />
**ubi apis- ibi salus**
Re: Brake & battery light stays on need help [Re: MnMsToY] #831511 08/20/07 03:53 AM
StillH2O_82 Offline
The charge light relay is on the passenger side tucked up under the dash. Gray box a little smaller than a half dollar. I am still looking for a replacement so in the interim I pulled the relay and the brake bulb from the dash. So far so good.
Re: Brake & battery light stays on need help [Re: StillH2O_82] #831512 08/20/07 05:11 AM
Scerb Offline
Check the ground cable from the alternator to the power steering bracket. Along with every other connection you can find of course...
Re: Brake & battery light stays on need help [Re: Scerb] #831513 08/21/07 02:54 PM
MnMsToY Offline OP
Thanks, I will pass it along.
Mike
PHP: 7.4.33 Page Time: 1.286s Queries: 15 (0.003s) Memory: 0.6185 MB (Peak: 0.7094 MB) Data Comp: Off Server Time: 2026-06-06 20:14:08 UTC
