sway bars
#831675
08/20/07 03:52 AM
The rubber bushings are all worn out, even gone on the drivers side. It makes a strange noise over rough bumps. I am using it for a hunting truck. It never goes over 55 MPH. I kind of just idle around my hunting camp. So do I "need" the front and rear sway bars.
I did a search and couldn't find out much. A lot on torsion bars but not much on the need for sway bars.
1990 MonTERROR 183.07 cubic inches of worn out FURY New ALTINATOR And uh... new radiator hoses UPPER AND LOWER, SAGGING COILS, dead SHOCKS Worn 29 x something x something else STREET TIRES GET SOME
Re: sway bars
[Re: Baldylocks]
#831676
08/20/07 04:07 AM
You don't need it. crank your torsion bars a bit, and take it off.
Re: sway bars
[Re: LandRaider]
#831677
08/20/07 04:27 AM
when you say it makes a strange noise what does it sound like I am just asking cause I have the same problem maybe I have 277,000 miles on my chassis and if you want to hear some noises I got several to choose from
Re: sway bars
[Re: jdchappell]
#831678
08/20/07 05:13 AM
I take my swaybar off (mine only has a front swaybar) every year after winter and put it back on right before winter. For traveling on rough terrain, removing the swaybar(s) makes the ride a lot more pleasant.
?_________ |_|_|\____\___ l-----[O]≡≡≡≡[O] ()_)()_)-----)_) Stay the Trail!
Re: sway bars
[Re: CapnCrunch]
#831679
08/20/07 07:29 AM
you can take them off, no problem. They help reduce body roll in turns. When the bushings wear out or the bolts come out it can rattle/clunk around when going over bumps. I have mine on and keep the bushings greased and in good condition since I drive on road alot and probably drive it much harder on road than I do off road(since I don't have a v8 sports car, I just have to drive the montero like it is one. lol) <img src="/forums/images/graemlins/evil.gif" alt="" />
1989 Montero 4dr V6 3.0l
Re: sway bars
[Re: 89montero]
#831680
08/20/07 01:17 PM
Re: sway bars
[Re: Baldylocks]
#831681
08/20/07 10:03 PM
I plan on using mine offroad only! No swaybar
89 Raider cranked t-bars,summit shackles 98 Land Rover discovery
