lash adjuster replacement #831984 08/22/07 03:10 AM
Baldylocks Offline OP
First and foremost I searched for lash adjuster replacement. I didnÆt find much. I have some pretty annoying tapping that gets louder as the engine warms up. When I am at a higher rpm it is not as noticeable. But when I am going slowly off road it bugs the heck out of me. Are they difficult to replace and does anyone think this would help the tap tap tap I hear?
Pat
1990 MonTERROR
183.07 cubic inches of worn out FURY
New ALTINATOR
And uh... new radiator hoses UPPER AND LOWER,
SAGGING COILS, dead SHOCKS
Worn 29 x something x something else STREET TIRES
GET SOME
Re: lash adjuster replacement [Re: Baldylocks] #831985 08/22/07 03:18 AM
jdchappell Offline
if you are going to take them off the heads you can clean them your self I put mine in diesel fuel I read that some where on here. after a few miles they tend to get that way. (dirty and stuck) If you are in the market for some new heads with new adjusters I have some be glad to hook you up <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: lash adjuster replacement [Re: Baldylocks] #831986 08/22/07 04:05 AM
Pete_D Offline
Sometimes they get varnished up over time. See if you can find some BG MOA oil additive at any local New Car Dealership. The service writers can tell you. It's usually used to augment services and won't be on display. Change your oil and add it in and leave it in. It's about the best cleaner/oil conditioner around and is the best shot at cleaning the valve followers the easy way. This stuff and their fuel injector cleaner is about the best available on the market. I'm sure you can also get it online. There is some on Ebay.
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
Re: lash adjuster replacement [Re: Pete_D] #831987 08/22/07 03:23 PM
Or it's a slapping piston, and not the HLA's.
Replacement should be pretty easy, but it's as much work as a timing belt replacement (which you should do), and take care in sealing back up, or you'll get an oil leak at the upper/lower cam bearing bosses at the front&back of the engine.
Re: lash adjuster replacement [Re: fasteddy] #831988 08/24/07 03:18 AM
Oh I HOPE it is not that. Thanks again for your help.
1990 MonTERROR
New ALTINATOR
GET SOME
Re: lash adjuster replacement [Re: Baldylocks] #831989 08/24/07 12:46 PM
toddstidham1 Offline
I've used transmission fluid in the oil to free up stuck lifters. On a 5 quart system, substitute one quart of dexron into the oil. Change oil and filter in about 1500 miles. Trans fluid is highly detergent and great at cleaning.
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: lash adjuster replacement [Re: toddstidham1] #831990 08/24/07 01:04 PM
FrankR Offline
Rislone
Frank
Re: lash adjuster replacement [Re: FrankR] #831991 08/24/07 02:01 PM
hazy_daze Offline
Rislone
Frank
x2 for Rislone. Used it before, worked well.
Re: lash adjuster replacement [Re: FrankR] #831992 08/24/07 06:06 PM
8
89IsMine Offline
Rislone
Frank
Same idea as above? Substitute 1 quart rislone for 1 quart motor oil and change oil+filter in 1500 miles?
Eric W.
Re: lash adjuster replacement [Re: 89IsMine] #831993 08/24/07 06:29 PM
hazy_daze Offline
You don't have to change the oil at 1500 miles. You can leave the Rislone in there.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6373 MB (Peak: 0.7605 MB) Data Comp: Off Server Time: 2026-06-15 04:46:59 UTC
