will an is spindle fit n a solid axle?
#832526
08/25/07 06:20 PM
i sheared off my hub studs and i have 2 ifs parts trucks in the yard. can you replace the spindle with an ifs spindle or are they different? i know i saw this somewhere im just hoping for a quick answer raher than going out in the squelching heat and looking for myself. that and im lazy <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: will an is spindle fit n a solid axle?
[Re: subliminaltrips]
#832527
08/25/07 07:35 PM
[Re: Jake97T]
#832528
08/26/07 02:54 AM
actually i was talking about the hub, not the lockout but the actual hub. got a good look at an ifs setup today but it looks a but different. i think to use the ifs hub with the fj rotors on a solid axle you need the widening kit from sky.
#832529
08/27/07 09:26 PM
Toyota Moderator
i think to use the ifs hub with the fj rotors on a solid axle you need the widening kit from sky. Correct.
[Re: ErikB]
#832530
08/28/07 07:06 PM
Toyota Section Staffer
And different axle splines in the hub... no match.
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
[Re: Red_Chili]
#832531
08/28/07 11:30 PM
well the spindles dont swap, the hubs will in fact swap also giving you a wider axle. the hub gears inside the ifs hub lock outs will not interchange. the hub dials do in fact interchange. the safest way to do it is to use the sky mfg widening kit, this thread shows the cheapest. http://www.pirate4x4.com/forum/showthread.php?t=218389&page=1&pp=25
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6094 MB (Peak: 0.6785 MB) Data Comp: Off Server Time: 2026-06-07 11:21:12 UTCValid HTML 5 and Valid CSS
