Re: HIGH OIL PRESSURE?? HELP ? [Re: BigJim] #832548 08/30/07 12:08 AM
Bigbird79 Offline
Personally I prefer Wix filters, or the Napa Gold filters, which are just re-packaged Wix filters. If you compare a Wix Air Filter to a comparable Fram filter, you will find more filter material in the Wix filter. More filter material = longer life, and better performance as a filter. Likewise the Wix oil filters have an anti-back flow valve, which will keep oil up in the engine instead of letting it drain back into the pan, so on the next start the engine still has oil.
Just my 2 cents, and sorry I got a bit off topic. smile
Sean
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: HIGH OIL PRESSURE?? HELP ? [Re: Bigbird79] #832549 09/05/07 12:31 AM
9
95jeep87camaro Offline OP
well guys...
i replaced the filter - and the oil pressure is STIll at around 70-75 psi.. its really bothering me
anybody have any ideas ... anyhting at all?
is it safe to drive the jeep daily runnning that high of oil pressure?
1995 jeep wrangler tan, stock, daily driver
and
1987 IROC-Z camaro : very modified
http://www.freewebs.com/iroczman15/
Re: HIGH OIL PRESSURE?? HELP ? [Re: 95jeep87camaro] #832550 09/05/07 03:47 PM
BigJim Offline
If the pressure TRULY is higher the only other thing it could be is the bypass valve in the oil pump.. If it worried me I'd get myself a new pump.. But I'd sure spend some time thinking about it before tearing the bottom off of my engine..
A genuine mechanical gauge telling me I had 75 lbs at hot idle would be enough to get me on my back...
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.5988 MB (Peak: 0.6681 MB) Data Comp: Off Server Time: 2026-07-17 03:54:20 UTC
