86 Gen I Montero help!
#832792
08/28/07 03:35 AM
Well i just picked up this pretty decent montero for 400 bucks. Its an 86 5spd has aisin hubs and it has a prblem with flooding itself and running rough.if u disconnect the fuel line from the carb u can get it to start and if u squirt gas into it it will stay running but when u hook the gas back in it floods out. These carbs are crazy looking any help?
Re: 86 Gen I Montero help!
[Re: Boostcreepr]
#832793
08/28/07 03:48 AM
Welcome !
21 year old carb...www.fcproducts.com. The carb is easy to replace IF you mark all the vac lines and take some digital shots.
Your other option if you don't have emission testing is the Weber Carb.
Make sure you use the search function, as there are a lot of great posts on the carb issue.
[Re: LRJ4x4]
#832794
08/28/07 03:52 AM
that carb scares me!! lol i was told its a 3 peice carb.. which sucks too <img src="/forums/images/graemlins/mrt.gif" alt="" />
[Re: Boostcreepr]
#832795
08/28/07 06:34 AM
After you read chapter 14 of the factory manual a few times you will feel better <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: LRJ4x4]
#832796
08/28/07 05:52 PM
Just make sure that if you R&R the carb (regardless of what you replace it with) that you ensure the mating surfaces of the carb and the intake manifold are pristinely cleaned of all the old gasket material and smooth. Any leaks there will translate to more problems afterward.
?_________ |_|_|\____\___ l-----[O]≡≡≡≡[O] ()_)()_)-----)_) Stay the Trail!
[Re: CapnCrunch]
#832797
08/28/07 07:07 PM
if you do not have any emissions testing I would seriously consider buying a weber. it makes your engine from having 1,000,000 vacuum lines into only 1. and its so simple to install. tuning them properly takes some time but once its set right you will love it!
[Re: torquemonster]
#832798
08/30/07 04:31 AM
i do have emissions and i seen the webber swaps are like 300 bucks! I only have a haynes manual so i dunno if thats the shop manual or what.  Ive just been staring at the carb trying to fix it physcoligically <img src="/forums/images/graemlins/scared.gif" alt="" />
[Re: Boostcreepr]
#832799
08/30/07 04:39 AM
i do have emissions and i seen the webber swaps are like 300 bucks! I only have a haynes manual so i dunno if thats the shop manual or what.  Ive just been staring at the carb trying to fix it physcoligically <img src="/forums/images/graemlins/scared.gif" alt="" /> 87 and 89 Factory Service Manuals If you have to pass emissions, your best bet is to stick with the Mikuni carb. Word is, the Weber won't pass.
[Re: CapnCrunch]
#832800
08/30/07 04:40 AM
[Re: CapnCrunch]
#832801
08/31/07 03:52 PM
will the 87-89 manual work for my 86? Also i heard that a 1986 - 1993 B2600 and Mighty Max carb would fit my motor is there any truth to this?
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6361 MB (Peak: 0.7596 MB) Data Comp: Off Server Time: 2026-06-21 04:40:12 UTCValid HTML 5 and Valid CSS
