tadem axles on a ford ranger
#833143
08/29/07 08:19 PM
I was just curious I havent figured out the engine replacement or anything I just wanted to get a genaral Idea about how to link the 2 diffirentials [color:"black"] [/color]
Re: tadem axles on a ford ranger
[Re: I_just_dont_know]
#833144
09/05/07 06:01 PM
take a tandem axle setup out of another pickup and throw it under the ranger may have to shorten things and have some stuff fab'ed though
[Re: milehighcowboy]
#833145
09/08/07 03:10 PM
Could you tell some of the other models that have a tadem axle I know of the dodge t-rex but every thing else is way to big for the frame that I know of There was a setup using a transfer case and a chain but I dont think that would hold up very. anymore suggestions would be greatly appreciated.
#833146
09/11/07 01:17 AM
If you have enough room for it use an old ford single speed transfercase turned around backwards behind your other case. You will have to mate the cases somehow and install a yolk where the old input used to be but that would give you 2 outputs then 1 for each rearend. use rear axles with offset diffs and a driveshaft with a carrier bearing for the rear most axle to go over the center axle. Sounds like a lot of work huh. You could use rockwell axles out of a larger truck they have flanges for just want you want to do. that is if you are going big. GOOD LUCK
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5965 MB (Peak: 0.6513 MB) Data Comp: Off Server Time: 2026-07-16 13:02:40 UTCValid HTML 5 and Valid CSS
