Page 3 of 3 1 2 3
Re: New Here! [Re: yankneck696] #833244 08/31/07 05:19 PM
You have leaking camshaft or crank seals from the oil in the timing belt cover, and oil kills belts. Change the belt and replace the seals. Change the crank bolt at the same time.
Headlight washers work when 1) the headlights are on, 2) the wipers are on (IIRC), and 3) the button on the stalk is pushed.
Re: New Here! [Re: Dieselburns] #833245 09/12/07 05:22 AM
DirtDriver Offline
Dieselburns, I just fixed my same turn signal problem by replacing the flasher with a new generic one from NAPA. (P/N NP552, $3.29) The first time I tried to fix it I used one pulled from a junkyard 1990 Montero, but it didn't make any difference. Either it was a weak design to start with or time had aged the components to the point where they didn't work well anymore.
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.5936 MB (Peak: 0.6581 MB) Data Comp: Off Server Time: 2026-06-25 00:18:25 UTC
