Rear Dif Oil #833324 08/31/07 01:57 PM
Bulletproof Offline OP
What kind of oil are we sticking in the rear dif? Front? The orange sticker inside my door indicates its an LSD?
1991 4D56T V44W JDM Mitsubishi Pajero
Re: Rear Dif Oil [Re: Bulletproof] #833325 09/02/07 11:05 AM
PartyTruck Offline
The bottle has a big smiley face on it. <img src="/forums/images/graemlins/smile.gif" alt="" />
You use a special oil for limited slip differentials, should be available almost everywhere where you can buy gear oil. You can also use standard gear oil and an additive for LSD diffs but the LSD oil is what I'd go for.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Rear Dif Oil [Re: Bulletproof] #833326 09/08/07 03:23 AM
PHIL_ Offline
Ron, I've used Crappy Tire's hypoid gear oil in the last 4 trucks - it does say that its suitable for lsd's... you can buy friction modifier from the Dodge dealer for about $12 if you get any chattering from the rear using regular gear oil, but I've never had any trouble with the Crappy tire stuff.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5901 MB (Peak: 0.6439 MB) Data Comp: Off Server Time: 2026-05-29 20:47:47 UTC
