trans lockout #833327 08/31/07 02:23 PM
dirtaddictionslv Offline OP
does anyone know what the eletric solenoid is called that controls the trans from shiftin in and out of park??
Re: trans lockout [Re: dirtaddictionslv] #833328 08/31/07 07:05 PM
Axe Man Offline
Kia Moderator Emeritus
Shift Lock Solenoid.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: trans lockout [Re: dirtaddictionslv] #833329 09/01/07 03:04 AM
blitz Offline
mine wouldnt shift out of park once.had a brake light out and some guy at the gas station i was stuck at,pumping gas next to me said he had the problem a week before,showed me the small key insert cover on right side of shifter on console.stick ignition key in there and it will let you shift into neutral then pull key out,start,shift down to drive. then go get some brake light bulbs.
hope its this simple for you,if not let axe know. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5908 MB (Peak: 0.6435 MB) Data Comp: Off Server Time: 2026-06-24 14:28:23 UTC
