fuel smell 2000Sportage #833366 08/31/07 05:32 PM
P
poppy1 Offline OP
Has anyone had a problem with the smell of fuel around the Kia Sportage I cannot find any leaks in the system but you can smell gas when the truck is standing it seems to go away when you drive a short time
Thanks Popy1
retired 18wheeler
Re: fuel smell 2000Sportage [Re: poppy1] #833367 08/31/07 06:45 PM
Axe Man Offline
Kia Moderator Emeritus
OK...intake manifold side of the engine. In front of the fuel rail. A round unit called the fuel pressure regulator. There are rubber hoses in that area with clamps. They often leak slightly causing a fuel smell. Either the clamps need to be tightened or the rubber has cracked.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: fuel smell 2000Sportage [Re: poppy1] #833368 08/31/07 07:06 PM
A
Airdale73013 Offline
If you top off your fuel tank you can have a problem with filling your charcoal canaster, located on the right side of the engine bay in front of the battery, with raw fuel and you will have a strong fuel smell.
2009 Sorento LX, 4x4, V6, Auto, Red
Re: fuel smell 2000Sportage [Re: Airdale73013] #833369 09/01/07 01:43 AM
DEFBOY35 Offline
there is also a recall for the top fitting on the fuel pump at the top of the gas tank that is known to leak and crack. that is what happened to mine. i found out about the recall after replacing the fuel pump. look at the top of the tank you should see it if it is there. leave the truck at idle and it will spray out.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: fuel smell 2000Sportage [Re: DEFBOY35] #833370 09/01/07 02:56 AM
blitz Offline
this sounds like a good peice of advice to remember <img src="/forums/images/graemlins/kewl.gif" alt="" /> so can i look at this area by folding rear seeat forward and opening some door i keep hearing about. i have never folded the rear seat up.just to see what i may(most likely)be in for one day.
Re: fuel smell 2000Sportage [Re: blitz] #833371 09/01/07 07:16 AM
DEFBOY35 Offline
yeah the rear seat just flips forward and there is a little trap door under there to get at the fuel pump. a few screws and it is off.
if you just look in the rear fender well also, where the fuel filler hose goes to the tank you will see the top of the fuel pump also. they mad the pump with an extremely cheap plastic elbow fitting at the top.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6067 MB (Peak: 0.6768 MB) Data Comp: Off Server Time: 2026-06-20 01:53:05 UTC
