Spark Plugs
#833376
08/31/07 08:15 PM
Hey, people! I'm new to the forum so take it easy on me if this question has been asked already. And no, I was to damn lazy to look through the old post for the answer. Thought I might get it faster and make a few friends, or enemies, if I just went ahead and asked. What have been the best spark plugs and wires for all of you who have a 1997 SR5 T100 with the 3.4L engine? I just purchased this truck a few weeks ago, and it seems to be burning gas like a mutha. Thought I might tune it up. It has 134,000 miles, and the previous owner looked as though he didn't know what the hell a tune up was. So I probably should check the plugs and wires just in case my shyte goes kaput! Thanks!
Keep it Simple!
1997 Jeep Wrangler 2.5L, 32x11.50 Mud Dawg Tires 15x8 AR-23 Wheels, 2" Rubicon Express Lift, FIPK, 4.0L TBI, Poweraid Spacer, Banks Torque Tube Header, Dynomax Ultra-flo Muffler
1997 SR5 T100 3.4L 4x4 (newbie)
Re: Spark Plugs
[Re: cneelyii]
#833377
08/31/07 08:36 PM
You'll get a resounding "stick with the Toyota OEM" from here. I have no experience with the wires/coil packs, but the plugs you get from your Toyota dealer (NGK or Denso) are far superior to the crappy Bosch plugs that I had in there briefly. With very few exceptions, when you're replacing parts or doing a tune-up Toyota parts are the only way to go.
Oh yeah, welcome! You'll find that it's a friendly and helpful bench around here.
1997 T 100 4X4 ExtraCab 5 speed, White Worthless factory bedliner 265/75/16 Firestone Destination A/Ts Aisin Manual Hubs 90k miles
Re: Spark Plugs
[Re: Perpetrator]
#833378
08/31/07 08:40 PM
Thanks! That's good to hear. And thank you for welcoming me to the forum.
Keep it Simple!
Re: Spark Plugs
[Re: cneelyii]
#833379
08/31/07 08:58 PM
First, welcome to the forum! <img src="/forums/images/graemlins/cheers.gif" alt="" />
I agree with using Toyota parts, especially the spark plug wires. NGK's and Denso's you can find at NAPA, or maybe one of those other parts places slightly cheaper than your local stealership. Most of the guys here deal with one of the following for Toyota parts or go their local dealer. You might want to check these out. DISCOUNT TOYOTA PARTS- Gettel Toyota- Carroll McMillen 941-739-5511 ext 4322, FAX 941-756-4339 (mention the T100 forum!) Conticelli Toyota Jay Marks Toyota
You might want to check out the FAQ's if you haven't already. A lot of info in there. .
Bill Reid '93 T100 SR5 4X4 '05 4Runner SR5 4x4 (wife's DD)
Re: Spark Plugs
[Re: Bill_R]
#833380
09/01/07 01:12 AM
www.sparkplugs.com sells oem ngk/denso wires and plugs for out trucks.
Re: Spark Plugs
[Re: CJMT100]
#833381
09/01/07 01:27 AM
The only problem with getting non-Toyota plug wires is they don't usually come with the little plastic clip that clips into the coil. If you screw up the original trying to take it off or if it is already broken, you end up with just a pushed in fit instead of a being clipped into the coil. But, there is always duct tape. <img src="/forums/images/graemlins/ignore.gif" alt="" />
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
Re: Spark Plugs
[Re: garym]
#833382
09/01/07 02:11 AM
The only problem with getting non-Toyota plug wires is they don't usually come with the little plastic clip that clips into the coil. If you screw up the original trying to take it off or if it is already broken, you end up with just a pushed in fit instead of a being clipped into the coil. But, there is always duct tape. <img src="/forums/images/graemlins/ignore.gif" alt="" /> Thats a possibility
Re: Spark Plugs
[Re: CJMT100]
#833383
09/01/07 06:07 AM
I bought a set of NGK wires and NGK plugs through that site and was very happy. About $55 shipped and they shipped quick. I haven't had a chance to drive the truck yet but they ran nice.
Re: Spark Plugs
[Re: cneelyii]
#833384
09/01/07 03:50 PM
welcome tp the fourm, I'm new here too. NGK or Denso is the way to go for sure. also you might want to replace the timming belt as well. I replaced my oem belt at 187,050 miles and it was 1 inch out of spec. I tell you what it runs like a champ now got plenty of power.
Re: Spark Plugs
[Re: cneelyii]
#833385
09/03/07 08:44 PM
Hello and welcome to the forum.
I will also very much agree to stick with oem parts. I bought my t100 about 6 weeks ago and also had some bad gas mileage. I have cleaned the maf with cnc maf cleaner ($4), changed the spark plugs (densos from dealership $2-3 each) as well as all the belts ($100), hi flow water pump ($100), pcv valve ($3 part), ECT sensor ($30 part & found out after removing it was fine) and oxygen sensors (both for $60). The 02 sensors I tried getting away with universals but they threw a code so had to order a denso or ntk and I went with the ntk 24554 because I found some really cheap and that got rid of the code. I have gained roughly 3mpg but have only ran one tank so far but am pleased if thats all I get since that will up it to 18mpg+.
Next up are the spark plug wires which I should have done instead of the ect ($@#%*! autozone) and those will definitely be oem and can be found for around $30-40.
Densos or ngk/ntk for plugs and those 2 brands will work for almost everything on these trucks and always worth the few extra bucks and in some cases they're cheaper. I know you only asked about the plugs I just thought I'd share my experience in gaining more mpg since my truck had the original plugs at 135,000 miles so routine maintenance also wasn't in my previous owners vocabulary and I have become pretty familiar with my engine in the last month.
Black 1998 T-100 4x4 ext/cab 265/70/15 on pacers and bilstein fronts
