Page 2 of 3 1 2 3
Re: My Monty and I Introduction / Tech Question! [Re: Boostcreepr] #833429 09/01/07 05:43 AM
LRJ4x4 Offline
It's not the timing chain to worry about...without oil pressure your engine will be seized in short order. If you don't have the factory oil pressure guage go buy a cheap one to confirm.
I'm pretty sure it's timing chain slap due to lack of oil pressure. Does the sound come from the front of the engine ? Hard to tell in the video.
Re: My Monty and I Introduction / Tech Question! [Re: LRJ4x4] #833430 09/01/07 05:57 AM
Boostcreepr Offline OP
yes definatly from the front of the motor. where would a good place to hook up an oil meter and should i get a mechanical or a electronic?
Re: My Monty and I Introduction / Tech Question! [Re: Boostcreepr] #833431 09/01/07 09:41 AM
highmtndesert Offline
I second the timming chain guides. had to turn off the video, could not stand to hear that sound again.
Well on my way to becoming that eccentric old man in every town.(crazy as a s#@thouse rat) With a yard full of desireable old vehicles that tells you, Sorry they're not for sale..... Someday I'm going to fix them.
Re: My Monty and I Introduction / Tech Question! [Re: Boostcreepr] #833432 09/01/07 02:28 PM
87Raider_TSI Offline
You can use the spot where stock gauge sender is located (near the oil filter) or there should be a plug in the block behind the water pump outlet. If I were mounting the gauge permanently I would go electrical, if you only plan to test the oil pressure I'd just get a cheap mechanical unit.
'87 Raider SWB 2.6T/5 spd - Boxy and boosted.
'88 Conquest TSI - MPI and lots of other mods
Re: My Monty and I Introduction / Tech Question! [Re: 87Raider_TSI] #833433 09/01/07 03:09 PM
so if my oil pressure is low how do i fix it when the dipstick reads full?
I was thinking maybe ill just give it an oil change and throw in some 20W50 that should give it some pressure if the oil pumps good and the oil is just watered down or somthing to lose its thickness. <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: My Monty and I Introduction / Tech Question! [Re: Boostcreepr] #833434 09/01/07 04:04 PM
toddstidham1 Offline
First, make sure the oil light comes on when you turn the ignition on (before you start) and goes out after you start it. If the ligh doesn't come on with the key on then you may want to pull the gauge cluster to change the bulb. Another check you can do, with the engine off but key on, go to the pass side of the engine and next to the oil filter is the oil sender (screwed into the block), pull the wire off the sender and ground it. Look to see if the oil light is on. you may just need a new sensor.
There is a manual adjustment you can do to the oil pump chain which may be the cause of the noise. There is an access cover down low on the front timing cover held on by two 10mm head bolts and behind that another 10mm head bolt for the chain guide. remove the cover, loosen the guide bolt and push the guide down onto the chain. tighten and replace everything and try again.
That evil laughing/scraping sound after you rev the engine sounds like something vibrating against something else...maybe a loose or rusted part/panel or some exhaust hanger?
It also sounds as though the lash adjusters aren't pumping up (an oil change may fix this) or you have the manual adjusted ones and need to adjust them yourself.
And welcome to the board!
Re: My Monty and I Introduction / Tech Question! [Re: toddstidham1] #833435 09/02/07 03:08 PM
are the lash adjuster for the timing chain? im going out now to try to adjust the oil pump but im going to change the oil too so i dont have to worry about that.
Re: My Monty and I Introduction / Tech Question! [Re: Boostcreepr] #833436 09/02/07 03:20 PM
Valve lash adjusters or lifters. If they aren't pumping up you will here a ticking/tapping sound that increases with engine speed. If the thing has been sitting for a while, there is likely quite a few noises you'll hear until you get good oil circulating around through the thing. A couple starts/runs/cool downs before you pass judgement. Change the oil and run it a few times. Hold the rpms @ 2000 for a minute or so then let it idle for a few minutes and repeat. I wouldn't drive it just yet until the engine quiets down some (which it hopefully will with fresh oil).
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: My Monty and I Introduction / Tech Question! [Re: Boostcreepr] #833437 09/02/07 04:35 PM
I just picked up some 20w/50 oil and a filter also got some oil treatment just to help clean up anything the old oil didnt keep clean
Re: My Monty and I Introduction / Tech Question! [Re: toddstidham1] #833438 09/02/07 06:46 PM
Oil light comes on and goes off, So thats okay, Next i took off the plate and loosened the bolt, now the little adjust pin inside do i push it down? or do i lift it up? Please verify quickly so i can put this back together before it rains lol. Thanks!
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6406 MB (Peak: 0.7493 MB) Data Comp: Off Server Time: 2026-06-18 13:12:14 UTC
