could wheel spacers affect flat towing #833909 09/04/07 01:41 AM
cbrazor Offline OP
iv always flat towed my yj with a tow bar the other day i went to tow it it wouldnt turn with my truck the only thing i changed was i installed wheel spacers could that affect it or is it somthing else <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
92 jeep yj re 4 inch lift revolver shackels front and rear 36 inch shocks in front 27 inch in rear 34 swampers ltb 2inch wheel spacers
Re: could wheel spacers affect flat towing [Re: cbrazor] #833910 09/04/07 02:12 AM
BigJim Offline
Ok so you DID HAVE the steering wheel unlocked...right?
The spacers shouldn't change the towability of the jeep. I have seen too much caster cause the front wheels of the towed jeep to slide and not want to follow the tow vehicle.
I like my vehicles to have a minimum of caster anyway so it has never been a problem for me.
Also if you have a front locker I doubt it would turn at all when towed.
Re: could wheel spacers affect flat towing [Re: BigJim] #833911 09/04/07 02:46 AM
cbrazor Offline OP
ok first yes the wheel was un locked
i do have a locker but i disengagsd it jacked it to cheak it each wheel turns indepently
Re: could wheel spacers affect flat towing [Re: BigJim] #833912 09/04/07 02:54 AM
cbrazor Offline OP
how do i cheak caster it drives fine no wear on tires and why would caster change
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6000 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-06-05 05:36:46 UTC
