iac valve help #834320 09/06/07 03:41 AM
U
uscpeon Offline OP
long story short, I broke the coolant fittings on the iac valve.
the parts store wont be able to get a replacement in time for my trip. (towing a race bike to the track)
So I bypassed the iac valve all together. the result is my idle is higher than normal (exactly how high, I don't know, no tach) and it surges (probably due to air in coolant system, will bleed again).
my question is will this temp. fix hold out and get me to the track and back safe? (6hr freeway drive one way). should i go or not?
1989 22re
Re: iac valve help [Re: uscpeon] #834321 09/06/07 04:24 AM
U
uscpeon Offline OP
update:
i've re-bleed the coolant system and the surgeing has stopped but idle is still higher than normal. safe or not safe to hit the road? help?
Re: iac valve help [Re: uscpeon] #834322 09/06/07 06:08 AM
U
uscpeon Offline OP
when out on a test drive, still idles high, and idle surges when i touch the brake. odd? what do you guys think?
Re: iac valve help [Re: uscpeon] #834323 09/06/07 06:09 AM
toyotaguy55 Offline
mines done that before, topped off coolant and it stopped and once i had to turn the air bypass screw on the side of the throttle body and it went away
toyotas look good with body damage
Re: iac valve help [Re: uscpeon] #834324 09/06/07 06:23 AM
4Crawler Offline
Surging w/ brake application is related to the high idle:
- http://www.4crawler.com/4x4/TLCA_TruckTech/TruckTech.04.09.html
My guess is it would probably fine for a highway drive. Might use a little more gas than normal, but no different than if you had you idle set too high for some other reason.
Re: iac valve help [Re: 4Crawler] #834325 09/06/07 07:20 AM
U
uscpeon Offline OP
thanks for the tips and assurance. I'll try turning down the idle tomorrow to see if the surging goes away, thanks again
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6077 MB (Peak: 0.6776 MB) Data Comp: Off Server Time: 2026-06-18 05:28:10 UTC
