Re: dsmisc.com ISC question [Re: 89IsMine] #834443 10/30/07 01:13 AM
G
generation_one Offline
To re-cap
"ISC, Mitsu 4G63 2.0L (DSM 1G/2G)" is the correct application for my 1989 Dodge Raider 3.0L. FastEddy said he had ordered the 2nd one shown on the page, so I suspect they are the same part. Eric W.
Two questions:
1) What vehicles the 4G63 2.0L ? I looked in junkyard to find some to "rebuild" and all the ones i saw were differnt. There was no triangle shaped cases, only rectangle. Maybe i was looking at the wrong thing?
2)And, what was the final price for this new one?
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: dsmisc.com ISC question [Re: generation_one] #834444 10/30/07 01:30 AM
G
the 4G63 2.0L ?
okay that's the Galant...according to chiltons book.
Vin V -SOHC
or
Vin R -DOHC
what years?
about 200k miles
Re: dsmisc.com ISC question [Re: generation_one] #834445 10/30/07 03:30 AM
8
89IsMine Offline OP
Two questions:
To answer #2, I don't remember the exact price off the top of my head, but it was around $140 for the ISC, o-ring, and shipping.
Eric W.
Re: dsmisc.com ISC question [Re: 89IsMine] #834446 10/30/07 03:57 AM
on cold soak start at fairly cool ambient temps, you will get an idle of about 1200 from the coolant activated fast idle valve which is seperate from the ISC in the TB. The FIDLE valve closes pretty fast, so I assume it activates at fairly low temp. The fidle valve is one of the reasons for the water hoses to the TB...
Re: dsmisc.com ISC question [Re: fasteddy] #834447 10/30/07 02:57 PM
8
89IsMine Offline OP
I must be missing something... was this in response to a different thread? I'm not understanding the relevance here <img src="/forums/images/graemlins/confused.gif" alt="" />
Eric W.
Re: dsmisc.com ISC question [Re: 89IsMine] #834448 10/30/07 03:33 PM
G
Aside from being a smart and helpful fellow, and a decent cuss generally, Feddy is also a psychic mind reader with strange powers. It could be that his words were intended to put the voodoo hex on the entire MPI system. With the changing season and cooler weather, that might be what I need.
I think my valve is stuck. It doesnt drop the RPM suddenly...only warming to operating temp will bring the idle to 770 from 1200+.
My Isc has an open circuit. It has been that way at least 6 months or so. Could be why I get not so good gas miles and delayed starts...
Re: dsmisc.com ISC question [Re: generation_one] #834449 10/30/07 05:03 PM
If I'm psychic, why am I broke...
Yes, a bad ISC will make for hard cold starts, but the CTS is a more likely culprit.
I was just pointing out that a 1200rpm cold idle is what it's supposed to do, and how it does it, unrelated to the ISC...
Re: dsmisc.com ISC question [Re: generation_one] #834450 10/30/07 05:19 PM
8
89IsMine Offline OP
Ooooh... Kay. Perhaps there was some PM'ing going on here because I didn't see anything in the thread about the FIAV... and then suddenly POOF! there it was <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
My idle starts out cold at 1500+ rpm, smoothly drops down to ~1200 rpm, and gradually down to 700 rpm as the temp needle rises above the tick mark on the gauge.
Anyways, I'll just stand by and watch you guys thrash this one out. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Eric W.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6327 MB (Peak: 0.7285 MB) Data Comp: Off Server Time: 2026-07-09 18:33:16 UTC
