in line fuel pump ?????????? #834551 09/07/07 10:36 PM
89toyOn35s Offline OP
Hey i have a 88 toy 30 4x4 and i need to know what fuel psi and gph i need for an in line fuel pump and fuel cell
i read somewhere 41psi and 24gph
also where can i get a fuel pump for that psi and gph
everything i have found is 6 and 7 sometimes 14 psi or does it matter? thanx everyone
Re: in line fuel pump ?????????? [Re: 89toyOn35s] #834552 09/07/07 11:22 PM
mosk Offline
Is your motor carb or EFI?
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: in line fuel pump ?????????? [Re: 89toyOn35s] #834553 09/08/07 02:15 AM
Adam F Offline
I'm guessing 30 meant 3.0 V6
97 4R, stock, daily driver
Re: in line fuel pump ?????????? [Re: Adam F] #834554 09/08/07 03:27 AM
mosk Offline
Well OP, assuming you have an EFI engine, you need an EFI pump. Any pump that puts out a static fuel pressure of >40 psi will do. What's wrong with using the stock pump? Unless you're adding a turbo or supercharger, it will work fine for just about any common mods.
If you want to look at an aftermarket pump, check out Walbro. Their high performance pumps come in various sizes and are affordable .
-Jeff
Jeff Moskovitz
Jeff's 22R-TE page
Re: in line fuel pump ?????????? [Re: mosk] #834555 09/08/07 03:34 AM
thanx for the site i am looking to get ride of the fuel tank under the truck and use a fire safe fuel cell for rollovers the old fuel pump i took out was not in working order from siting for 7 years 1/2 the tank was gum what can i do to get the gum out of the fuel lines and fuel injectors? + is there anything else i need to do befor trail riding with it next weekend
Re: in line fuel pump ?????????? [Re: 89toyOn35s] #834556 09/08/07 06:00 AM
OOP'S Offline
Some have used an in-line pump from a Celica, do not know what year they are on. But they pick them up at P-N-P wrecking yards.
Get a spray can of carb cleaner, disconnect lines at both ends, and shoot it in until it comes out the other end. Let it sit for a while then blow it out with air. Repeat. You should do it on all the lines, main, return, C.C. vent line, and anything else that carries gas. There may be a few things that need to be replaced like the fuel pressure regulator, pulsation regulator. . As far as the injectors, send them out and have them cleaned and balanced.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: in line fuel pump ?????????? [Re: OOP'S] #834557 09/08/07 07:49 PM
pulsation regulator wtf i didn't even know anything about that what does it do and were is it at on the motor ??
also can i not clean the injectors myself letting them soak in carb cleaner
Re: in line fuel pump ?????????? [Re: 89toyOn35s] #834558 09/10/07 07:15 PM
Red_Chili Offline
Toyota Section Staffer
No you cannot.
It runs $16 per for clean and balance, so there is no reason to NOT send them out.
-Bill
Re: in line fuel pump ?????????? [Re: 89toyOn35s] #834559 09/10/07 10:56 PM
dcg9381 Offline
You may already have a pulse regulator on the fuel rail.. I don't know the 3.0L.
You just need an inline pump.. I believe the guys on pirate recommend a pump (Ford) from one of the E-series vans.
Bosche, Kinsler, lots of options...
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6268 MB (Peak: 0.7300 MB) Data Comp: Off Server Time: 2026-06-05 19:26:51 UTC
