Re: engine/tranny install [Re: MAC] #834893 09/13/07 04:51 AM
MAC Offline OP
Anybody?
Re: engine/tranny install [Re: MAC] #834894 09/13/07 06:39 AM
toyrunner Offline
Anybody?
I set the output from the transfer on a floor jack, dollie, or the like and remove the crossmember.
Start pulling and then separate on the ground That's what I meant
Th
Danny
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: engine/tranny install [Re: toyrunner] #834895 09/14/07 03:42 AM
MAC Offline OP
Thanks. I assume when chaining to the two engine pull hooks all the weight is on the rear hook with the tranny/xfer attached. Does this work out ok? Would it help to put a strap or chain around the front of thr tranny also? (if it can be done). I'm just about ready to do it...
Re: engine/tranny install [Re: MAC] #834896 09/14/07 03:48 AM
toyrunner Offline
Just angle the chain so it is towards the back. When the tcase is about to clear the rad support, I lift it up and over. Works better with two people, one can do it
Make sure the hoist rolls easily, spray the wheels with lube. Makes for a better job.
Danny
1985 SR5 4Runner
4.7:1 single case
Re: engine/tranny install [Re: toyrunner] #834897 10/02/07 01:30 PM
MAC Offline OP
ready to pull. seems all the weight will be on the one rear lifting hook... think it would help to install another lifting hook say, in the threaded hole for the starter to get a little more support? or am i worrying too much here?
Re: engine/tranny install [Re: MAC] #834898 10/02/07 02:12 PM
toyotaguy55 Offline
just pull it youll be fine <img src="/forums/images/graemlins/kewl.gif" alt="" />
toyotas look good with body damage
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6135 MB (Peak: 0.6837 MB) Data Comp: Off Server Time: 2026-07-15 00:09:02 UTC
