engine/tranny install #834883 09/09/07 05:26 AM
MAC Offline OP
Is it possible to insatll the engine and tranny as a unit? (87 4Runner/22re)
Re: engine/tranny install [Re: MAC] #834884 09/09/07 07:48 AM
toyrunner Offline
I have done that several times, 85 4Runner. T-case attached also. Easier in my opinion.
Danny
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: engine/tranny install [Re: toyrunner] #834885 09/09/07 02:20 PM
MAC Offline OP
As far as the length of the unit and angle to get it into the engine compartment and under the firewall, do I have to get the truck pretty high off the ground?
Re: engine/tranny install [Re: MAC] #834886 09/09/07 02:41 PM
DRTDEVL Offline
I did not have to lift my 87 at all to install the entire drivetrain as a single unit... But it was also sitting on 33's w/3" BL.
You might need to lift it a little, but it won't be much.
Re: engine/tranny install [Re: MAC] #834887 09/10/07 01:24 AM
Snowtoy Offline
You will want to remove the hood to install it as one unit, you shouldn't have to lift the vehicle at all. If you have a body lift it will be easier either way, either as a unit or by the piece. However, w/o a BL the upper bell housing bolts is a PITA when installing the tranny, though it still can be done.
Re: engine/tranny install [Re: Snowtoy] #834888 09/10/07 02:19 AM
MAC Offline OP
Maybe I should back up here...I may be making some incorrect assumptions. The big picture: I am swapping engines. The tranny in the truck is ok. Based on my past experience with trying to wrestle the tranny/xfer in after a clutch job, I am thinking it would be easier to pull both out as a unit, or individually, then bolt the tranny to the good engine and install as a unit. I am assuming it would be easier than leaving the tranny in and trying to mate the new engine to it. What do you think?
Re: engine/tranny install [Re: MAC] #834889 09/10/07 02:31 AM
toyrunner Offline
I concur. Replace engine/trans/transfer as 1 unit.
Drop the trans/transfer as 1 unit with a floor jack. I leave the cross member attached. It is a good lever:D
Good time to clean engine bay and transmission
Assemble all together and install!
You will have to remove the cross member for obvious reasons
Easy and you'll see when you do it!
So do it <img src="/forums/images/graemlins/notooth.gif" alt="" />
1985 SR5 4Runner
4.7:1 single case
Re: engine/tranny install [Re: toyrunner] #834890 09/10/07 02:57 AM
MAC Offline OP
Many thanks. I'm too old to be bustin myass any more than I need to.
Re: engine/tranny install [Re: MAC] #834891 09/10/07 03:18 AM
toyrunner Offline
I just turned 50 last month. <img src="/forums/images/graemlins/scared.gif" alt="" />
I use all the shortcuts available!
1985 SR5 4Runner
4.7:1 single case
Re: engine/tranny install [Re: toyrunner] #834892 09/12/07 05:56 PM
MAC Offline OP
So do it
Toyrunner: You mention above pulling tranny/ xfer out from bottom.
What is the advantage of not pulling engine/trannt/xfer out as a unit? Thanks.
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.009s) Memory: 0.6358 MB (Peak: 0.7596 MB) Data Comp: Off Server Time: 2026-07-15 07:47:51 UTC
