Tire size
#835163
09/10/07 09:47 PM
What is the biggest size tire I can fit on the Sportage without a lift? 2000 4wd 4dr I have 215/75 all terrain tires on it now but I want to put on some rough tires and need to go a little bigger. I am getting 22 - 24 mpg now and don't want to kill the mileage so I prefer not to lift the rig unless I have too.
Re: Tire size
[Re: Sportage0]
#835164
09/11/07 12:08 AM
You can use the search feature to find answers to common questions such as this. Here's a link to a thread that will fit the bill on this one: Tire size Good luck ks
'99 Sportage 4dr EX 5-speed, unmolested '98 Sportage 4dr Auto 2wd '96 Sportage 4dr Auto,235-75x29"tires, custom fabbed hidden receiver hitch and big plans.
Re: Tire size
[Re: Sportage0]
#835165
09/11/07 12:16 AM
235x75x15 on the stock wheels is as big as I would go without a lift. You might be able to squeeze in 30s if you stay with the stock wheels. You might loose a little MPGs with the 235s but not much. Dennis
95 Sportage, gone but not forgotten. 98 Jeep TJ, 4" Zone springs with RC Long arms, Ford 8.8", 4.56 gears & Detroit locker rear, D30, 4.56 & Detroit Trutrack front.
Re: Tire size
[Re: DennisThompson]
#835166
09/11/07 02:26 AM
if you go much bigger, even without a lift you will lose some mpg. if you stay narrower though it shouldn't be as bad.
i know with my 31x10.5's it suffers a lot!
Re: Tire size
[Re: DEFBOY35]
#835167
09/11/07 05:58 AM
The largest tire size that I did without a lift was 30x9.5
on 15x8 rims with +offset---and I had no problems (major). <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Tire size
[Re: Hydra747]
#835168
09/11/07 01:40 PM
30x9.5 fits on stock rims too, with only very minor rubbing on the sway bar at full-lock turns.
95 Sportage w/welded and 5.89 geared dana 44's on 38.5" TSL's.- SADLY SOLD CURRENTLY - 2000 sportage, 5.38 gears, welded diffs, 35" tires, 5.5" lift http://www.cardomain.com/ride/341410
Re: Tire size
[Re: Dave Scott]
#835169
09/12/07 07:34 PM
Thanks for the info. That is what I was hoping to hear. I have found a good deal on a set of 235's. I pull a small boat and a 6x10 trailer with a 4 wheeler on it. I pull both trailers alot since this in my hunting rig. Any experience and how much the taller tire will affect my pulling power and also the affect on mpg?? I have always drove full size trucks with big V8's so I don't know what to expect from putting a larger tize on the small 4 cylinder. I appreciate all your help!!!!
Re: Tire size
[Re: Sportage0]
#835170
09/13/07 12:50 AM
I have never towed with mine but I didn't notice much of a drop in gas milage or power with the 30x950s but I did add a K&N open filter and a 2 1/4" exhahst with a MagnaFlow. When I went to the 31s I felt a drop in both milage and power but not enough to make me go smaller tires again. A good air filter and open up your exhaust and It should pull ok with the 235s. Dennis
Re: Tire size
#835171
09/13/07 08:34 AM
i got 235's on mine and i take a trailer up the beach camping, i dont notice alot if difference in economy unless im giving it some stick. it will be slightly worse economy becauce u have a larger rolling diameter but nothing to bad.
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
