Square tube doors? #835186 09/11/07 12:09 AM
Adam F Offline OP
I'd really like to have a set of tube doors, but cannot afford to buy a set. I was thinking about making a set out of square tube since I don't have a bender. Have any of you guys made any out of square tube? I'd like to see some pics.
97 4R, stock, daily driver
Re: Square tube doors? [Re: Adam F] #835187 09/11/07 08:46 PM
Snowtoy Offline
I don't think square tube doors will look that much different than round tube one do, might actually fit the lines of the 2nd gen a little better.
You could get an idea by fabricating one out of wood, an 8'x2"x2"(actual size is 8'x1.5"x1.5") should be enough, and shouldn't run you more than about $4. You can also use the wooden pattern to have an exhaust shop with a tube bender bend you the pieces you need to make your own tube doors. Most shops charge about $10/bend for standard bends, so about $40-$80 for both doors, depending on if you just have two corners bent for each door, or four.
Re: Square tube doors? [Re: Snowtoy] #835188 09/12/07 12:13 AM
toyotaguy55 Offline
toyotas look good with body damage
Re: Square tube doors? [Re: toyotaguy55] #835189 09/12/07 12:22 AM
Adam F Offline OP
Thanks for the link. These look like something I'd like to make...
Re: Square tube doors? [Re: Snowtoy] #835190 09/12/07 12:23 AM
Adam F Offline OP
Good idea, but I probably won't go through the trouble of doing that, since I'm on a budget. I'll just cut and weld the square tube to fit.
PHP: 7.4.33 Page Time: 1.399s Queries: 15 (0.009s) Memory: 0.6057 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-07-15 08:19:18 UTC
