Electrical Problem and Need some help
#835224
09/11/07 01:05 AM
We went hunting and had found one of the roads were blocked and in turning around we hit some pretty rough bumps and from that time on we lost all dash gauges and the fan and funny enough the 4 wheel dont lock in. Took it to toyota and they can not find the trouble. We replaced the fuse in side the cab and it blows the fuses every time. Could it be behind the dash??? Toyotoa never did look there...
Re: Electrical Problem and Need some help
[Re: jlelbert]
#835225
09/11/07 08:49 PM
What fuses blow?
With the wiring diagram you would be able to identify the circuits on those fuses. It shows you where the wires are mounted on the truck.
97 T100 4x4 97 328i 95 540i restoration project
[Re: jlelbert]
#835226
09/12/07 03:14 AM
I have had bad experiences with the main plug that is on the firewall going into the interior on American products. As most manufacturers use a multi pin big plug to get stuff to the interior, could be you rocked it loose. find it and try giving it a good hard wiggle. If things get better, you now where to look.
trafdlo
[Re: jlelbert]
#835227
09/12/07 04:03 AM
Those dummies don't know how to troubleshoot. Drop your skidplate and get under there and do a visual on your wiring, and your vacuum to the front diff (assuming ADD diff setup). Yeah-- WHAT FUSE? You troubleshoot downstream from there; the fuse did its job as a safety device. <img src="/forums/images/graemlins/shame.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 18 (0.008s) Memory: 0.6162 MB (Peak: 0.7193 MB) Data Comp: Off Server Time: 2026-10-30 20:19:58 UTCValid HTML 5 and Valid CSS
