Page 5 of 6 1 2 3 4 5 6
Re: 2.6 Liter = 17.5 mpg!?!?!?!?!? [Re: billygoat] #835379 09/15/07 06:58 PM
ryany Offline
If you want to get really technical with the math, you have to calculate for the actual tire diameter, which changes as the tire wears. A 33" tire is rarely exactly 33", and won't remain at that size throughout it's life. For example, suppose a 33" tire has 15/32 tread when new. When it's worn to 3/32 of tread depth, it will have decreased to a 32 1/4" tire (12/32 worn x 2 sides = 3/4"). The Tire Rack website has all the technical data for every tire it sells including actual width & diameter measurements. It's interesting to look at how many 33" tires aren't really 33" diameter.
95 Montero SR
Brain Fart..... [Re: ryany] #835380 09/17/07 01:57 PM
TripleJackInGA Offline
After working myself into a frothy mess thinking about this, I've figured you guys are exactly right, and I was exactly opposite of actual on this one.
If you travel an indicated 1 mile in a truck with oversized tires, you have actually traveled further than 1 mile.
Sorry for the fuss, lol!
TripleJack
85 GenI SWB 2.5/5-Speed on 33s
Re: Brain Fart..... We all have them. [Re: TripleJackInGA] #835381 09/18/07 06:31 AM
TripleJack,
For the difference made by swapping from the stock size to 33" tires, my indicated mileage isn't affected that much. Depending on my project load and type, certain tire combos are better than others. I've just put the 33's back on because I'm close to home and working on a sandy fill for the new Folsom Bridge. When I was going to Tahoe everyday, 140 to 170 miles with highway only, lots of high speed downhill corners over the 6,000 foot differential between my office and the project site, it made more sense for the stock tires. I like stopping. Aside from the braking woes (:z:), I'd run the 33's all the time.
Russell
Re: 2.6 Liter = 17.5 mpg!?!?!?!?!? [Re: TripleJackInGA] #835382 09/19/07 12:13 AM
BobShaw Offline
I got 15.5 mph with my 2.6L and 31" muds. I now get 20.5mph with a 4.3L and 32" muds. You figure?
Re: 2.6 Liter = 17.5 mpg!?!?!?!?!? [Re: BobShaw] #835383 09/19/07 07:16 AM
LRJ4x4 Offline
I was told the 2.6 is a old diesel tractor motor design <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: 2.6 Liter = 17.5 mpg!?!?!?!?!? [Re: LRJ4x4] #835384 09/19/07 02:11 PM
I have also read Mitsu fork-lifts.
Re: 2.6 Liter = 17.5 mpg!?!?!?!?!? [Re: MontyMcV] #835385 09/19/07 05:50 PM
Baldy Offline
I got 13 mpg with my 2.6 with 31" tires, 4.22 gears but I was never able to use 5th gear due to the gearing.
I get 17 mpg with the swapped in V8.
Re: 2.6 Liter = 17.5 mpg!?!?!?!?!? [Re: Baldy] #835386 09/24/07 12:17 AM
TresMon Offline OP
Where's the best deal on a webber?
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Welded front,tight LSD in the rear
Removed bump stops
4'x6' roof rack
10k. Lb. winch on receiver hitch/custom bumper
100 amp alt
CB radio/AC inverter
S.Winch hubs
Enormous RV battery
Re: 2.6 Liter = 17.5 mpg!?!?!?!?!? [Re: TresMon] #835387 09/24/07 03:57 PM
E
EyeOnCy Offline
http://www.racetep.com/montero.html
Go through this site and find the application. I ordered from them when they were offering freeshipping. I've seen like 2 Webers on ebay in my time of owning this, but they didn't have the adapter plates. Just order this, its not cheap, but you get EVERYTHING you need w/ easy to follow instructions. I've never worked on a car before and I installed it and tuned it.
1989 Dodge Raider 2.6L/5spd
2004 Honda Element EX
1989 Dodge Daytona Shelby Z
1993 Toyota P/U
Re: 2.6 Liter = 17.5 mpg!?!?!?!?!? [Re: EyeOnCy] #835388 09/24/07 08:25 PM
TEP and cheap prices generally do not get spoken in the same sentence...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6456 MB (Peak: 0.7534 MB) Data Comp: Off Server Time: 2026-06-07 05:52:32 UTC
