Roasted distributor cap #835418 09/12/07 01:08 AM
Buck Offline OP
My truck wouldn't start the other day when I was leaving work. After a few mins of troubleshooting, I found that the center conductor of the distributor cap was roasted. Looks like it got so hot that plastic around it got all crispy and brittle. I have the Jacobs Off Road ignition, which puts out more than a stock setup, but never seen this before. Had a Supercoil on a different vehicle with no problems. Only about 5000 miles with the Jacobs setup. Anyone else seen this before? Maybe just a bad cap? High resistance in the center pin, plus lots of voltage equals lots of heat? Anyways, seems to be running fine now with a new cap, I'll have to keep an eye on it.
84 Ext. Cab Pickup.
Re: Roasted distributor cap [Re: Buck] #835419 09/12/07 01:49 AM
mosk Offline
I've seen this on a few vehicles. It typically happens when the carbon element in the center of the distributor cap cracks or wears excessively. As the gap between the cap element and rotor grows, the spark jumping the gap gets hotter and hotter, further accelerating the wear on the element. Replace, and make sure the new cap and rotor don't get contaminated with any grease when you reinstall.
-Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: Roasted distributor cap [Re: mosk] #835420 09/22/07 03:56 AM
Buck Offline OP
Had another no spark problem today, of course, at work when I was heading home. Truck wouldn't start, checked the distributor cap, looked good. Pulled a plug to check for spark, had buddy crank it and all of a sudden I had spark and truck fired and was running on 3 with one in my hand. <img src="/forums/images/graemlins/zombie.gif" alt="" /> I got home and checked the resistance on the signal generator, was a little high, so I replaced that, hoping it fixes the problem. Anyone had anything similar with a Jacobs ignition? <img src="/forums/images/graemlins/confused.gif" alt="" />
84 Ext. Cab Pickup.
Re: Roasted distributor cap [Re: Buck] #835421 09/28/07 04:28 AM
Buck Offline OP
Still fighting the no spark problem. I installed the stock ignition so that I can just swap a few connectors from the Jacobs to the stock setup when the problem occurs. My question is, what is the little electronic pack that attaches to the side/rear tab of the stock coil setup? Couldn't find any pictures or description of it in the manual I have. Found that the truck wouldn't run unless it was electrically connected to the stock coil, so since my Jacobs setup is in the original location, I had to run a jumper from the electronic pack to the tab on the side of the stock coil. Just curious as to what that thing is, Thanks.
84 Ext. Cab Pickup.
Re: Roasted distributor cap [Re: Buck] #835422 09/28/07 04:32 AM
stock87 Offline
Little square-ish black thing with the blue and black wires going into it? Dunno, but I always figured it was some kind of resistor.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Roasted distributor cap [Re: stock87] #835423 09/28/07 05:51 AM
Buck Offline OP
Yep, that's it. Truck won't run unless it's electrically connected to the side of the stock coil pack.
84 Ext. Cab Pickup.
Re: Roasted distributor cap [Re: Buck] #835424 09/29/07 12:57 PM
rustylux Offline
That there would be called a ballast resistor.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6177 MB (Peak: 0.6929 MB) Data Comp: Off Server Time: 2026-06-13 03:52:03 UTC
