KIA Sportage û sputtering - misfire - no power - check engine û smoke - PO303
#835753
09/13/07 06:14 PM
My Sportage was having problems After searching Sportage internet sites, I saw many others had a similar problem I put a check list of possibilities together for you Prnt This Out and Take to Your Mechanic
SYMPTOMS Engine Not overheating Check engine light is flashing code PO303 - Cylinder 3 misfire detected car sputters has no power if driven for a time white/gray smoke comes out if driven for a time muffler becomes SUPER hot
Have Your Mechanic Check These: harness wire to coils (kinda hidden in back) û this is what fixed my Kia coils leads timing timing belt tension muffler o2 sensor fuel filter spark plugs CSP sensor rust in lines MAF sensor vacuum leak throttle sensor leaking gasket mass air flow ignition timing cadillac converter Idle control valve injectors flooding crank position sensor injection flush may fix it spring missing on cylinder 3 No ground at injectors 1 and 3 exhaust gas recirculation valve sticking injector comes and goes 2 wires skinned or repaired with tape gap the new spark plugs they don't come pre-gaped coolant leaking into the cylinder - coolant covering the piston Bosch +4 plugs cause the engine to misfire - Go the original spec NGK plugs are really fouled like an injector leaking down - then flow test is bad
Re: KIA Sportage û sputtering - misfire - no power - check engine û smoke - PO303
[Re: HpyUnBday]
#835754
09/13/07 07:08 PM
Kia Moderator Emeritus
Most of the time the cure for misfire is simply worn out spark plugs. When was the last time they were changed?
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5885 MB (Peak: 0.6375 MB) Data Comp: Off Server Time: 2026-06-09 23:10:20 UTCValid HTML 5 and Valid CSS
