Stuck Zippers #835852 09/13/07 09:12 PM
bradford_johnson Offline OP
Hello all;
Spare me the innuendo about getting my zipper stuck at a difficult time, but as the weather begins to change here in the northwest, I found myself this morning having a difficult time zipping up my windows after sitting in the garage all summer. Any recommended lubricant (again, no jokes please) for the zippers to smooth this annual process?
2004 TJ Wrangler Sport
Re: Stuck Zippers [Re: bradford_johnson] #835853 09/13/07 09:49 PM
BigJim Offline
A little beeswax might help.. Can you take the strain off of them and zip them a few times while loose? That might help get them acustomed to their job again..
Re: Stuck Zippers [Re: BigJim] #835854 09/13/07 10:42 PM
Thanks Jim. I was speaking with a co-worker who uses "chapstick" on his boat and that seems to do the trick.
Re: Stuck Zippers [Re: bradford_johnson] #835855 09/14/07 03:11 AM
kewlynx Offline
Dishwashing liquid is helpful. Beeswax is good for when you're ready to put the boat up for the season to keep it nice. If ya can't find any, PM me.
**ubi apis- ibi salus**
Re: Stuck Zippers [Re: bradford_johnson] #835856 09/14/07 02:15 PM
DBL_DTY97TJ Offline
For the back one I find it easier if the bar at the bottom is pushed in first and the tabs hooked so it pulls the window tight before zipping.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Stuck Zippers [Re: bradford_johnson] #835857 09/14/07 09:52 PM
BobRowe Offline
In the past, I found the following to be very effective on zippers as they get cruddy or remain either opened or zipped for a long period of time:
Metal zippers: Vaseline
Plastic sippers: Silicone spray
After coating the zipper with the above, work the zipper up and down it's entire length a few times. Repeat in 2 weeks.
Re: Stuck Zippers [Re: BobRowe] #835858 09/15/07 05:49 AM
gtrotta Offline
Try StarBrite Marine White Teflon for snaps and zippers.
Works great on baby strollers too -- the teflon repels water and dirt.
1987-2000: '87 black Raider stock 4-cyl/5-speed.
2000-2006: '89 black Raider stock 6-cyl/auto
2007-?: 89 black Raider, 6-cyl/auto w/(at last!), bouncy seat, power windows and cruise.
Re: Stuck Zippers [Re: gtrotta] #835859 09/15/07 03:21 PM
BigJim Offline
I remember having a bar of IVORY soap in a cj just for rubbing on the zippers.. It worked then so I betcha it would work today also.
Re: Stuck Zippers [Re: BigJim] #835860 09/17/07 05:07 PM
Seattlegti Offline
I always used plain old candlewax. Just take a candle stub and rub it hard into the teeth. Liquids and sticky stuff like vasaline attract and hold grit, #1 enemy of soft cast zinc sliders.
If you ever need to replace the sliders on your soft top pick up some stainless steel ones from a marine upholtery supply shop, they'll never corrode again!
Take an old slider in with you if you go out shopping for new ones. The #8 and #9 coil sliders look almost identical and will not work if swapped.
Re: Stuck Zippers [Re: Seattlegti] #835861 10/02/07 11:34 AM
hlhneast Offline
Call me crazy, but Mopar has a zipper lube for Jeep soft tops. I have seen it on Ebay. I dunno if its worth the 6 or 7 bucks they want or if it works good as I have never used the product. If yer vehicle is under warranty, you might want to use this stuff until it runs out in case the zippers rip out or something. <img src="/forums/images/graemlins/notooth.gif" alt="" />
77 fiberglass CJ-7 304, Ground up Resto-mod Edelbrock Air Gap, Holley 1850, Headers and Flowmasters, Black Diamond suspension, BFG 33X9.50 on Outlaw I's. Hopefully on the road this year!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6289 MB (Peak: 0.7358 MB) Data Comp: Off Server Time: 2026-06-09 12:03:06 UTC
