Tires squeal #835930 09/14/07 04:43 PM
sixpacktr Offline OP
Just a quick question. When I turn, my wheels squeal. I notice it more when in a parking lot, and more on new asphalt, but always nonetheless when I make a tight to semi-tight turn.
I have wide wheels on it, like most Jeeps (Timberlines, I believe).
What would cause this? Am I out of alignment?
98 Ford F150 XLT
68 Triumph TR250
When looking for a reason as to why things go wrong, never rule out sheer stupidity...
Re: Tires squeal [Re: sixpacktr] #835931 09/14/07 05:26 PM
BigJim Offline
The geometry of the front wheels is deceided at the factory with stock setback wheels in mind.. When changing the setback of the wheels the geometry is changed. THIS alone can cause tire wear and squeal when turning.
The squeal is caused by tire SLIDE SIDEWAYS on the surface of the road.
Re: Tires squeal [Re: BigJim] #835932 09/14/07 05:37 PM
So, what do I do? Can this be 'fixed'?
98 Ford F150 XLT
68 Triumph TR250
Re: Tires squeal [Re: sixpacktr] #835933 09/14/07 08:26 PM
BigJim Offline
Prolly not totally fixed! But resetting the caster to less positive may help. Also 0 camber may help.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5997 MB (Peak: 0.6550 MB) Data Comp: Off Server Time: 2026-06-12 03:38:14 UTC
